Running New Gas Lines In The Attic From LP Tank - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-01-2012, 09:25 PM   #1
Running new gas lines in the attic from LP tank
Hi guys well I have another project, I'm installing a 250 gallon LP tank out side my house and I need to run the LP lines thru the attic to my garage and kitchen. I really don't know where to start as far as what type of lines to use. Any help here I'm sure I can handle the project but I need to get educated before . Thanks
ogoz23 is offline   Reply With Quote
Old 04-01-2012, 09:33 PM   #2
Rewards Points: 13,266
The gas company should be doing this, not a DIY. One of the jobs that can make your house go boom and people die.
If you have to ask how to do it, then on this one you should not be doing it.
Old 04-01-2012, 10:02 PM   #3
Ok I would still like to learn about this , if Anyone has any inputs , on type of lines etc .
Old 04-02-2012, 07:53 AM   #4
What he said. Many localities allow the homeowner to do most anything in his own house, running gas lines is not one of them. If it is wrong, the results can be deadly. If you want to learn, check local plumbing code with referrence to gas lines.
Old 04-02-2012, 08:34 AM   #5
Master Plumber
Javiles's Avatar
Rewards Points: 990
If you want to learn, itís best that you watch the contractors when they install the line, multiple factors need to be taken into account, example BTU ratings type of materials to be used, distance from the service tank to the unit, I doubt t someone on this site will give you a how to do it in this situation Most gas companies are not delivering or filling LP tanks without a permit final and approval.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Help with new duct work trunk running to attic from basement. coderguy HVAC 8 10-02-2011 11:22 AM
running A/C lines in a wall JulesB HVAC 6 01-19-2011 07:36 PM
Garage over Septic tank and Leach lines canyonbc Building & Construction 11 01-13-2010 11:48 PM
Insulating wall when running Copper Tube lines to an exposed wall face scubber Carpentry 5 04-13-2009 11:23 PM
(new) toilet tank running unexpectedly tarheelblue Plumbing 2 09-07-2008 01:46 PM
