Old 07-02-2009, 05:52 PM   #1
Default Running lines to baseboard heater using Pex.
So I've been researching Pex more because it seems much easier to work with than copper and it's cheaper. A friend has the tool to crimp so I figured I could purchase some tubing and give it a go. The two plumbing projects I need to tackle are moving the washing machine and re-routing the baseboard heater to a new wall. I'm concerned about the baseboard because I don't know how hot the water gets; will Pex work fine for that?
Basically the pipes that go to the baseboard now travel from one corner of the room, all the way around the room to the adjacent corner is started in. Why..I have no idea but it's very inefficient and a waste of pipe. My plan is to remove all of that copper and just re-run it using Pex the correct way. Will Pex work fine for this, are there any potential issues I may run into?
RyanD is offline   Reply With Quote
Old 07-02-2009, 06:37 PM   #2
Experienced goon
Manufacturers have a special heating-specific pex that also has an oxygen barrier integrated. Usually referred to as radiant pex, it's the product you'd use for a radiant floor, and also for running to radiators.
So they're different products, the pex for potable, and the pex for heating.
jpelzer is offline   Reply With Quote
Old 07-03-2009, 01:52 AM   #3
something to consider is if their is a headder running several heating loops or elements, they have to be within 10% of each others length, unless a balancing headder is in use. If one loop is significantly shorter than the others, it will get the majority of the flow. Also as Jpelzer said their is a difference in pex types, the heating pex has an oxygen barrier, and it is usually, but not always colored red. The pex for heating will be stamped as such and state,"not for potable water".
plumbob1234 is offline   Reply With Quote
Old 07-04-2009, 09:08 PM   #4
Default flow
rd. also remember pex flows less water than copper. particularly with insert fittings. noticeably less. read some flow charts. breid
breid is offline   Reply With Quote
Old 07-05-2009, 12:18 AM   #5
Experienced goon
Probably not noticeably less, at least not to a single fixture.
http://www.toolbase.org/PDF/CaseStud...r_pressure.pdf
Old 07-05-2009, 09:32 AM   #6
You two plumb nice now, or youl both get a time out. PS. before I take a side is the copper reemed or non.
More On This Topic
What you see here is a solar water heater. So totally different to photovoltaic or to solar electricity. This one is just using the sun to heat up water. And when you look close, I opened it up for you that you can see what's going on there. In here is... Read More »
When you're trying to save money each month in energy costs, one of the first and best places to make a change is in the hot water system of your home. Homeowners can end up spending hundreds of dollars more per year than they should as a result of an... Read More »
Now, there is an aesthetic issue that I want to take care of before I start making all my cuts and preparing all my notes to place on the xylophone bar. And that is, when you buy a copper pipe from the hardware store it's going to have red lettering on... Read More »
Solar Powered Water Heaters
Solar Powered Water Heaters by Expert Village
Also is that we heat our water with the sun and that's another reason we can use these batteries because you're water heater is costing you every month about at least 8 to 15 dollars. So, and that's a lot of electricity. And if we would run our water... Read More »
wiring a 240V baseboard heater 777 Electrical 10 05-17-2009 12:47 PM
Insulating wall when running Copper Tube lines to an exposed wall face scubber Carpentry 5 04-14-2009 12:23 AM
Electric Baseboard Heater Problem goombie Electrical 9 12-23-2008 02:13 AM
Baseboard Heater: Can I wire it to plug into an AC recepticle? JBiz Electrical 3 12-01-2007 10:42 AM
Baseboard heater Help! jweinstock Electrical 6 10-28-2006 06:01 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
