Running Fridge Water Line. - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-03-2013, 09:46 AM   #16
Originally Posted by Fix'n it View Post
that is because = it is.
i had to use what i had on hand.
no need. after the new counter tops and sink go in. it will be done properly.
this is just temp as far as the drains go.
Very innovative as long as its temporary
Peppe1019 is offline   Reply With Quote
Old 11-03-2013, 09:50 AM   #17
Rewards Points: 1,958
What is that sideways trap under your sink supposed to accomplish?
Ghostmaker is online now   Reply With Quote
Old 11-03-2013, 09:50 AM   #18
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,216
Originally Posted by Hardway View Post
I ran copper for my ice maker.
On the fridge itself has plastic line thou.
Any thoughts?
The plastic line on the fridg is after the solenoid valve and is not subject to constant water pressure pressure. Not in danger of bursting and flooding the house.
Coastal South Carolina
Old 11-03-2013, 10:19 AM   #19
That question has been asked and answered....
Old 11-03-2013, 09:36 PM   #20
Rewards Points: 236
Originally Posted by PoleCat View Post
It's still OK if we snicker at it a little bit ain't it?
sho nuff is
Fix'n it is offline   Reply With Quote
Old 11-03-2013, 09:40 PM   #21
Rewards Points: 236
i am using the plastic. i think you guys are not giving it its due.
i drilled the base cabinets for the line. 1/2" hole. to service, pull out fridge, pull out line. to reinstall, tape new line to a stick and poke it through.
on to the next job.
Old 11-04-2013, 05:37 AM   #22
Rewards Points: 1,216
on to the next job.
Plastic ice maker water lines suck. Always use copper with coils rolled up in back of frig so it can be pulled out for service and cleaning.
No Warranty Means- If it breaks in half you get to keep both halves.
COLDIRON is offline   Reply With Quote
Old 11-04-2013, 07:22 AM   #23
Rewards Points: 1,322
If plastic lines suck I suspect my wife thought of a lot of descriptive words for this. It was only her thoughts but I probably said them after the phone conversation while I was 300 miles away.
Old 11-04-2013, 07:56 AM   #24
JOATMON
ddawg16's Avatar
Rewards Points: 1,834
You must be using the wrong kind of plastic. I have plastic and no issues. But the again, I have mine properly attached and it's easy to access and work on.
ddawg16 is online now   Reply With Quote
Old 11-04-2013, 08:09 AM   #25
A "Handy Husband"
rjniles's Avatar
Are you addressing plastic pipe (PEX or CPVC) or the plastic tubing to connect to the ice maker solenoid valve?
Running that plastic tubing under cabinets or in hidden areas in a recipe for disaster.
Using plastic pie is fine.
Old 11-04-2013, 08:17 AM   #26
JOATMON
ddawg16's Avatar
I use polyflow...not that thin wall stuff you get at HD or Sears. What I use is rated for about 1000 psi
Old 02-20-2017, 05:07 PM   #27
Rewards Points: 492
Re: running fridge water line.
joetab24 is offline   Reply With Quote
vacuum breaker question detroittigerfan Plumbing 17 10-12-2013 01:37 PM
Sealing a water line to the back of fridge. Sojumonkey Plumbing 7 10-06-2013 12:42 PM
Leaky ball valve at incoming water line Bipin1948 Plumbing 5 10-03-2011 05:21 PM
water pouring into basement from around water supply line matty8199 Building & Construction 29 12-29-2009 05:07 PM
Need Advice - How to run Fridge Water Line Joshcube Plumbing 3 03-20-2009 04:56 PM
