Running Fridge Water Line. - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-03-2013, 08:17 AM   #1
Rewards Points: 222
running fridge water line.
i need to run the line through cabinets. should i run it through the base of the cabinet, or through the inside of the cabinet(lower rear corner) ?
Fix'n it is offline   Reply With Quote
Old 11-03-2013, 08:25 AM   #2
PoleCat's Avatar
Rewards Points: 1,646
If you are going through multiple cabinets under the base may be impossible without pulling the cabinets to drill inside panels.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
Old 11-03-2013, 08:25 AM   #3
Rewards Points: 582
pictures help..but if you can't do any other way ..do it so you can repair it if you have to.....ben sr to answer your question ..your choice..
Old 11-03-2013, 08:27 AM   #4
Rewards Points: 13,300
No way to tap into a line under the floor and run it to a real ice maker box?
http://www.amazon.com/Oatey-38823-Tu.../dp/B000VLBLRY
Old 11-03-2013, 08:41 AM   #5
Rewards Points: 222
said cabinets are not installed yet. valve for fridge water is already installed under sink. and i installed it so that nearly any person, disabled/handicaped even, could turn it off.
servicing the line. if i go through the base. it could be easily pulled out. then a new line could be taped to a rod and run through to the DW area.
Old 11-03-2013, 08:51 AM   #6
PoleCat's Avatar
Looks like you got it made. Only concern I would have over going through the base is water damage from late detection of a leak. Mouse decides to bite hole in the line and it takes awhile for you discover the leak. 40 years ago plastic pipe was a rupture hazard but I think we are out of the woods on that. I think I would go that route despite my paranoia.
Old 11-03-2013, 09:08 AM   #7
Rewards Points: 222
i do have the plastic line. imo, it is more durable, all things said.
mice, not an issue. neighborhood cats take care of the outside. out 2 cats cover the inside.
all the work i have done to this house, i have yet to see 1 mouse turd. but yeah, i know what your say'n.
yeah, the leak issue.
Old 11-03-2013, 09:13 AM   #8
bbo
I'd think any leak would go undetected unless you leave the doors open or the line running on top of the counter. I would not use that as a determination as to where to run the line.
Still concerned, get something like this: http://www.thewateralarm.com/wateral...er-Filter.html
note I've had icemakers for 15ish years, no leaks yet. of course, my house may fall into a sinkhole one of these days as I don't have alarms on everything.
bbo is offline   Reply With Quote
Old 11-03-2013, 09:14 AM   #9
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,142
Run flex copper not that plastic tubing they sell as an icemaker kit.
Coastal South Carolina
The Following 5 Users Say Thank You to rjniles For This Useful Post:
ben's plumbing (11-03-2013), COLDIRON (11-04-2013), Hardway (11-03-2013), oh'mike (11-03-2013), raylo32 (11-04-2013)
Old 11-03-2013, 09:22 AM   #10
DIY staff
Rewards Points: 7,174
I see you are on an outside wall---to bad.
there are water line boxes that can be tucked into the wall---which allow you to use the new,braided water feed lines---I like using those whenever possible.
Old 11-03-2013, 09:36 AM   #11
Bill Kearney
Rewards Points: 1,174
I second the suggestion to use flex copper. Out of sight situations like this are often worth using a less-likely-to-fail material like copper instead of plastic.
I had them run the lines for a dishwasher under the base of two cabinets to get to the power, water supply and drain. I put a 2" hole in the back lower corners, but also put a 1x4 cleat on the back wall along the length. This to add a bit of support for the loss of where the hole was cut. Fishing the lines across once the cabinets and counter were installed actually went much easier than expected. The key was using a hole bigger than the bare minimum needed. The hole in the floor of the sink base was 'dressed up' using a wall escutcheon cover like the kind you'd normally use to surround the PVC going into the wall.
And make sure to put in an actual valve for it. Don't use a vampire tap.
As for leaks, wouldn't you know it, when I reinstalled our fridge I neglected to put some teflon tape on the threads and it leaked a bit. Fortunately we left things accessible and noticed the slight drip quickly enough to avoid any damage. It took longer to find where I'd packed the tape than to do the clean up! So don't neglect to use proper sealing materials AND check the connections periodically. Both right after the install and regularly after that. A water alarm would certainly be worth having, for this or for any location that has constantly connected water supplies.
wkearney99 is offline   Reply With Quote
Old 11-03-2013, 10:31 AM   #12
The kitchen sink drains look a mess.. Why do you have a trap installed as a 90? Has it been leaking? Would like to see the rest of it so we can help you pipe that in properly...
Peppe1019 is offline   Reply With Quote
Old 11-03-2013, 10:38 AM   #13
Rewards Points: 222
that is because = it is.
i had to use what i had on hand.
no need. after the new counter tops and sink go in. it will be done properly.
this is just temp as far as the drains go.
Old 11-03-2013, 10:43 AM   #14
PoleCat's Avatar
It's still OK if we snicker at it a little bit ain't it?
Old 11-03-2013, 10:43 AM   #15
I ran copper for my ice maker.
On the fridge itself has plastic line thou.
Any thoughts?
Hardway is offline   Reply With Quote
vacuum breaker question detroittigerfan Plumbing 17 10-12-2013 02:37 PM
Sealing a water line to the back of fridge. Sojumonkey Plumbing 7 10-06-2013 01:42 PM
Leaky ball valve at incoming water line Bipin1948 Plumbing 5 10-03-2011 06:21 PM
water pouring into basement from around water supply line matty8199 Building & Construction 29 12-29-2009 06:07 PM
Need Advice - How to run Fridge Water Line Joshcube Plumbing 3 03-20-2009 05:56 PM
