Running DWV Pipe From Shed To House - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-13-2008, 02:00 PM   #1
Rewards Points: 1,062
Question
running DWV pipe from shed to house
there is probably about 50 ft between the shed and the spot in the basement where the pipe would be tying in to. does the size of the pipe matter ? i will be using it for a utility sink in the shed. normally, that requires a 1.5 in pipe. i was gonna go with 2 in just in case.
thanks,
- a -
Old 03-13-2008, 03:22 PM   #2
Journeyman Plumber
Ron The Plumber's Avatar
Go with 2"
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Old 03-13-2008, 03:28 PM   #3
Exclamation
thank you sir !
Old 03-14-2008, 03:11 PM   #4
Send a message via AIM to Marlin
I'd run 3" so if you ever want to add a bathroom or anything else the line is already there.
Marlin is offline   Reply With Quote
Running electric to a shed msajeep Electrical 18 04-13-2011 05:59 PM
Popping noise where PVC pipe leaves house sb5115 HVAC 8 01-18-2011 02:16 AM
Pipe noise upstairs bathroom when running only warm water dial2fast Plumbing 1 12-03-2007 11:39 PM
Complete AC installation in Old Capitol Hill Row House jacko10 HVAC 0 09-18-2007 05:42 PM
