Running Drains For Basement Bath - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-03-2009, 07:26 PM   #1
Running drains for basement bath
Hello everyone! I'm in need of some advice and some answers. I'm in the process of running drains in the basement bathroom. I am wanting to have a drain for a tub and then a drain for a separate shower. I would like them to be on the same line. The builders left me with a rough in that ended up just being a pipe. I have included pictures.
Questions
1) Does the tub and shower require thier own p-trap or will one trap work?
2) With the rough pipe at an angle what is the best layout of pipe work? (I was thinking a 45, straight, 45, straight, p trap, 22.5, straight, p trap)
Any other comments are welcome. Thanks!
Pic of the rough pipe the line indicates the angle.
jeerme is offline   Reply With Quote
Old 03-03-2009, 08:08 PM   #2
without being there, first guess at what I might do
II Weeks is offline   Reply With Quote
Old 03-04-2009, 11:59 AM   #3
does the shower drain need venting? or is the rough pipe already vented somewhere?
thanks!
Old 03-04-2009, 07:11 PM   #4
what do you mean by rough in pipe? is that the existing pipe?
If so, it probably is vented but check with local codes as far as how many feet between fixtures is a vent required.
Vents are really easy to run and will help you in the long run with flow.
Old 03-04-2009, 09:51 PM   #5
yes the rough in pipe is the existing pipe.
thanks for your help.
any other comments are welcome. thanks guys!
New drains under the basement floor, guidance needed mason Plumbing 6 01-10-2009 04:58 PM
Switching the Plugs in Bath Fan/Light MrBill_DIY Electrical 3 12-01-2008 06:45 PM
Complex challenge with bath exhaust fan - need help with solution! Honest Bill Electrical 6 11-02-2007 02:52 PM
pipe size for tub, floor, and bath sink drains amakarevic Plumbing 2 07-25-2007 07:29 AM
NO bath water running!!! rath Plumbing 1 09-09-2005 12:13 PM
