Running Drain Through Studs, According To Code? - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-26-2012, 11:44 AM   #1
running drain through studs, according to code?
Hi,
The plumber doing my basement plumbing is running kitchen drain through the studs (drilling them) to the old washroom drain. the length of the running is 27 feet and it has 10 elbow(90 degree) from kitchen to old drain. Is it according to Ontario code?
thanks
navid is offline   Reply With Quote
Old 05-26-2012, 11:58 AM   #2
concretemasonry's Avatar
Rewards Points: 2,568
Not much information and I am not familar with the details of the Ontario code, good principles apply to everything.
Is the wall load bearing?
What size holes does he propose to drill? - If there is a code and permit to protect you, he should be aware of the minimum requirements.
Is there protection (depth or plates) to prevent later nails for piercing the pipe walls?
Dick
concretemasonry is online now   Reply With Quote
The Following User Says Thank You to concretemasonry For This Useful Post:
navid (05-27-2012)
Old 05-26-2012, 01:01 PM   #3
Drilling studs to run drain lines is a common practice but there are certain guidelines that need to be followed. Could you provide pics of the work in question so we can get a better idea of your concerns?
VIPlumber is offline   Reply With Quote
The Following User Says Thank You to VIPlumber For This Useful Post:
navid (05-27-2012)
Old 05-26-2012, 01:52 PM   #4
MarginallyQualified
Rewards Points: 2,464
Originally Posted by navid View Post
...27 feet and it has 10 elbow(90 degree) from kitchen to old drain.
Whether it meets code or not... 27 feet of pipe and 10 elbows is NASTY.
There has to be a better way but the obvious ones are 1) to pay for them to break up the concrete floor or 2) pay the carpenter to have a 'soffit' like box for the pipe to be in. Would you like either of those choices better?
The Following 2 Users Say Thank You to TarheelTerp For This Useful Post:
navid (05-27-2012), TheEplumber (05-26-2012)
Old 05-26-2012, 02:51 PM   #5
...the length of the running is 27 feet and it has 10 elbow(90 degree) from kitchen to old drain. Is it according to Ontario code?
thanks
Oops, missed that part. Something is definitely wrong here.
navid (05-27-2012)
Old 05-26-2012, 06:05 PM   #6
here is the plan for the basement. Kitchen drain starts from the pink circle and the existing drain are the red ones. Thanks for your ideas.
I have a drain tile coming from the backyard running under the garage floor..The sump pump emptiesinto the tile.The drain tile runs from the garage to the street. 15utter76 Plumbing 2 03-01-2012 03:17 PM
Scupper drain installation advice needed miamicuse Roofing/Siding 9 02-11-2012 10:59 AM
Boring studs for Sink drain spring3100 Plumbing 4 12-10-2011 10:47 PM
minimum drain pipe for bathroom sink to code Lindy_B Plumbing 0 02-17-2011 10:34 PM
running washer drain sedwick Plumbing 8 02-12-2007 06:10 PM
