Running Copper Pipe Through Bottom Plate? - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-15-2011, 04:36 PM   #1
JOATMON
ddawg16's Avatar
Rewards Points: 1,122
I am starting on a 2-story addition to my house. I already have my 3/4" water line sticking out from the existing house through a hole I drilled in the bottom plate. I have a few more lines to run and I need to drill through other plates to get the water where I want.
I'm assuming this is ok? I sure hope so....the other options are not pretty.
Here is a pic of the main line coming out....I still need to run the hot water line as well as gas.
Old 08-15-2011, 05:04 PM   #2
biggles's Avatar
looks neat i would put a shut off on any and all line coming from the house ...gas and or water with in that crawl space opening easy access. cut pieces of pvc slid down the pipes to where it comes thru the wall if concreted in to keep the copper and concrete from reacting into your retirerment years...just an opinion
Old 08-15-2011, 05:14 PM   #3
JOATMON
ddawg16's Avatar
You can't see it very well in this photo....but the pipe where it comes out of the plate does have a ball valve on it....that will allow me to work on the plumbing in the new addition without shutting off all the water to the front part of the house.
I need to take a pic of the pipe coming through the bottom plate so you see exactly what i'm talking about.
Old 08-15-2011, 11:59 PM   #4
JOATMON
ddawg16's Avatar
Here is a closeup of the one pipe I have already ran throught the bottom plate.
Old 08-16-2011, 12:16 AM   #5
Plumber
TheEplumber's Avatar
Rewards Points: 452
nothing wrong with running pipes through wood like that, but I use an 1 3/8" bit for copper lines up to 1". This size of hole will accept what is called "pound in" pipe isolators. They protect the pipe from rubbing against the wood.
Looking for a step by step for framing basement walls/2x4's wrong direction/stairs??? xray328 Remodeling 27 06-19-2011 09:50 PM
PVC air admittance value and copper waste pipe diy888 Plumbing 2 02-16-2011 08:48 AM
Bottom Plate for Non-Load Bearing Wall cobrakai Carpentry 2 02-08-2011 12:56 PM
Bernoulli's Principle, increase 3/4" pipe to 1-1/4" or 1-1/2" copper ChrisDIY Plumbing 14 09-18-2010 10:49 PM
Copper pipe size question greymous Plumbing 18 01-30-2009 05:02 PM
