Run Supply Pipes On Unfinished Sides Of Studs - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-05-2009, 04:55 PM   #1
Run Supply pipes on unfinished sides of studs
Wanted to ask and get thoughts on if its ok to run the supply pipes for my basement bathroom on the unfinished surface of the wall. I framed the wet wall with 2x4's, but am thinking I should have used 2x6. There is a vent in the wall so I cannot run a straigt line of pipe.
So should I run the pipes on the utility room side, i am never going to finish this room?
Or should I redo the wall with 2x6's and notch the pipe in the wall?
Thanks,
Bryan
bkeech is offline   Reply With Quote
Old 02-05-2009, 05:05 PM   #2
Safe, Most of the Time!!
brokenknee's Avatar
You could always fir out the wall with 2X2s. Make sure you use a steel plate over the pipe to prevent running a screw or nail into it.
"Clarity to Agreement" Dennis Prager
Picture/Photo Pitcher/Carafe ------- Where/Someplace Were/Be
brokenknee is offline   Reply With Quote
Drain Pipes, Walls and Studs mattaparity Plumbing 2 12-18-2011 07:22 AM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
using 8' studs vs 7'-9" studs RINAIL Carpentry 2 07-10-2008 04:16 PM
Is it normal to see green stuff on the supply pipes KUIPORNG Plumbing 2 06-30-2006 11:21 AM
Can water supply pipes be PVC?? i need general help... hallbum Plumbing 5 12-10-2005 01:22 AM
