Run Gas Line In Room On Slab - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-30-2008, 06:39 PM   #1
run gas line in room on slab
I have a small dilema, I want to install a gas fireplace in a room that is on a slab and has a cathedral ceiling, next to this room is a utility room that has the gas line in it. The run would be about 32 ft 3/4 inch pipe, how can I run this? In the room somehow? or outside the room?
Scott NJ
stanen8871 is offline   Reply With Quote
Old 11-30-2008, 08:32 PM   #2
Registered User
Termite's Avatar
Run it outdoors....Buried? Pop it back in by the fireplace.
Old 11-30-2008, 10:30 PM   #3
how deep do I need to go for a gas line, and what kind of piping would I use?
should I use the yellow flex cable?
Do I come out of the utility room in a sleeve?
Old 11-30-2008, 11:50 PM   #4
Registered User
Termite's Avatar
Most underground installations are plastic line. It must be buried 12". You'd need a plumber to do the plastic line for you. Black iron gasline can be buried if protected with a wrap, if approved by the codes authority in your area (the code gives them the option).
Old 12-01-2008, 12:32 PM   #5
Check your local codes for underground gas piping. Most steel lines underground must be welded (no threaded or compression joints). Some areas allow soft copper, outside the home. The plastic lines require a licensed Plumber to make the connections.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 12-01-2008, 03:47 PM   #6
Registered User
Termite's Avatar
Where is that required? I'm unaware of any such requirement in the I-codes...
Old 12-01-2008, 03:59 PM   #7
I have run tons of underground gas lines (from 3/4 to 8") when I was in Ohio. All steel lines were welded. All were also required to be coated and, depending on soil conditions, had an anode bag Cad welded to them. The plastic came along during my last 5 years there. The gas company inspected all gas installations. Guess this is another of those "check local code" issues.
Old 12-01-2008, 09:53 PM   #8
Can I run black iron 3/4 pipe outside the room above ground 6 inches up from the ground along the outer wall then 90 degree elbow into the room in a sleeve?
Old 12-01-2008, 11:15 PM   #9
I would think that is a good idea. Just make sure it is secured well in case something falls on it or someone would use it for a step. You may also want to consider marking it so no one makes a mistake and cuts into it.
Leak in incoming supply line under slab playstationdork Plumbing 13 08-05-2008 09:18 AM
Tapping into 3"DWV line under basement slab cshaffer Plumbing 3 04-22-2008 05:48 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
Moving a gas line when house is on a slab Socrmom3 Appliances 4 01-24-2008 12:32 AM
Radiant Heating on Cement Slab can'tdecide Flooring 2 08-21-2007 01:59 PM
