-   -   run gas line in room on slab (http://www.diychatroom.com/f7/run-gas-line-room-slab-32891/)
stanen8871 11-30-2008 06:39 PM
I have a small dilema, I want to install a gas fireplace in a room that is on a slab and has a cathedral ceiling, next to this room is a utility room that has the gas line in it. The run would be about 32 ft 3/4 inch pipe, how can I run this? In the room somehow? or outside the room?
Scott NJ
Termite 11-30-2008 08:32 PM
Run it outdoors....Buried? Pop it back in by the fireplace.
stanen8871 11-30-2008 10:30 PM
how deep do I need to go for a gas line, and what kind of piping would I use?
should I use the yellow flex cable?
Do I come out of the utility room in a sleeve?
Termite 11-30-2008 11:50 PM
Most underground installations are plastic line. It must be buried 12". You'd need a plumber to do the plastic line for you. Black iron gasline can be buried if protected with a wrap, if approved by the codes authority in your area (the code gives them the option).
majakdragon 12-01-2008 12:32 PM
Check your local codes for underground gas piping. Most steel lines underground must be welded (no threaded or compression joints). Some areas allow soft copper, outside the home. The plastic lines require a licensed Plumber to make the connections.
Termite 12-01-2008 03:47 PM
Where is that required? I'm unaware of any such requirement in the I-codes...
majakdragon 12-01-2008 03:59 PM
I have run tons of underground gas lines (from 3/4 to 8") when I was in Ohio. All steel lines were welded. All were also required to be coated and, depending on soil conditions, had an anode bag Cad welded to them. The plastic came along during my last 5 years there. The gas company inspected all gas installations. Guess this is another of those "check local code" issues.
stanen8871 12-01-2008 09:53 PM
Can I run black iron 3/4 pipe outside the room above ground 6 inches up from the ground along the outer wall then 90 degree elbow into the room in a sleeve?
majakdragon 12-01-2008 11:15 PM
I would think that is a good idea. Just make sure it is secured well in case something falls on it or someone would use it for a step. You may also want to consider marking it so no one makes a mistake and cuts into it.
