Run Dishwasher Drain Under Floor? - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-08-2013, 01:35 PM   #16
Is your basement open? Could we get a picture below the kitchen of the sink drain and/or rafters?
dabeast is offline   Reply With Quote
Old 10-08-2013, 03:52 PM   #17
I was able to figure how to make an custom length extension. I was able to find a coupler that will fit both inside the drain hose and inside a reinforced braided rubber hose. I also got a new adapter for the sink drain that will fit inside the rubber hose.
I also found out that the dishwasher drain has a check valve in it. So water will not backfill into the unit itself. I am going to try to run the line in the back of the cabinet. I got a piece of crown molding to cover the line once I am done.
I will post back when I am done.
psuarmy is offline   Reply With Quote
Tags
dishwasher , drain
Water backup into basement floor drain after jetting lateral and sanitary sewer sm2327 Plumbing 4 04-01-2013 12:18 PM
Floor Drain Question colesy Plumbing 11 03-24-2013 05:07 AM
Frozen Garage Floor Drain Dragon General DIY Discussions 8 01-25-2009 06:07 AM
Wierd Floor Drain "Backup" rawkintrevo Plumbing 9 06-04-2008 07:10 PM
Basement Floor Drain amazinlittledevil Plumbing 8 01-04-2007 01:17 PM
