Roughed In Plumbing - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-28-2012, 02:57 PM   #1
Roughed in plumbing
Hello,
I purchased a new home about 2 years ago, when they built the house they were supposed to rough in the basement bathroom. Turns out they didn't so they had to come back, drill the floor and rough it in. The toilet and sink drain seem to be very close together to me, would you be able to take a look at the picture below and let me know what you think? I plan on putting the sink on a wall to the right of the toilet, would it be fine for me to run about 4 feet of PVC on a slop from the sink to that roughed in drain?
Also, I would assume the sink drain would already be vented right? Would I be able to connect the shower vent to the sink vent as well or do I need to run a totally different vent?
Thanks again, this site has been a great resource!
Uploaded with ImageShack.us
tucker16 is offline   Reply With Quote
Old 02-28-2012, 03:11 PM   #2
MarginallyQualified
Rewards Points: 2,464
Originally Posted by tucker16 View Post
The toilet and sink drain seem to be very close together to me...
They're fine. Well, so long as you install the sink to the LEFT of the toilet.
...would it be fine for me to run about 4 feet of PVC on a slope....?
Yes.
No. That pipe *may* be connected to a vent but I'd assume not.
Plan to extend that pipe up through the house somehow or other to the roof.
What shower?
If you want a shower down there too then call them back to cut the floor for those fittings.
Old 02-28-2012, 03:16 PM   #3
Rewards Points: 13,278
May be just the angle of the picture but the distance from the toilet drain does not look like 12 1/2" from the wall to the center of the drain.
It also looks like the space from the wall to the toilet drain is way to small to allow a sink to go in there.
http://www.us.kohler.com/designkb/de...ceplanning.jsp
Old 02-28-2012, 04:45 PM   #4
Hello,
The center of the toilet drain to the wall is 12", when they roughed in the plumbing I was a bit thrown off by where they placed it but a different builder also did the same thing in my sisters new place which makes me think this might be common place in Ontario.
We are thinking about putting a shower in the basement, basically what I am wondering is if I tie the shower drain into the sink drain pipe under the floor do I also need to vent the shower separately or is it fine as it is since it will be connected to the same vent as the sink already is? I have attached an image of what I am looking to do, my graphic skills aside (which are none lol)
Thanks again!
Old 02-28-2012, 05:51 PM   #5
Plumber
TheEplumber's Avatar
Rewards Points: 452
you can put the lav there and drain it into the toilet vent but you will probably need to revent it's trap arm due to your proposed length
The shower will need to be vented as well and then all vents should vent through the roof unless you can use autovents.
Did the plumber leave a capped vent in the ceiling joist space?
BTW the lav line probably wye's off the toilet line a feww feet from the toilet stub- not the way you drew it
Old 02-28-2012, 06:08 PM   #6
Yes they have a capped off pipe in the corner running up to the roof for venting purposes, so I will run a vent off of the shower as well and then vent the sink there. Thanks again, you guys are awesome and have been a huge help!
Old 02-28-2012, 11:41 PM   #7
Is that the current measurement or is there an allowance for drywall and other wall finishes, ie - tile?
VIPlumber is offline   Reply With Quote
Old 02-28-2012, 11:47 PM   #8
Rewards Points: 582
if it 12"from rough wall finish wall would be 11 1/2 tight for a 12" rough commode address now or you will have to get a 10" rough commode .
Old 02-29-2012, 09:25 AM   #9
Rewards Points: 150
Agreed. I think the max dirty arm is 5'. So just revent the sink.
Question for Eplumber (or any other master plumber). If the sink did not drain into the toilet vent, would this vent be considered illegal, because it likely comes off the toilet branch horizontally?
psilva8 is offline   Reply With Quote
Old 02-29-2012, 09:49 AM   #10
Plumber
Rewards Points: 452
This varies by local. As a standard though, all vents must rise vertical to a point 6" above the flood rim of the highest fixture. However, since you are under a slab, structural conditions make it impossible so your method of venting is excepted- or so it goes per UPC
What is the standard method of water pressure test for shower plumbing please? Andy21 Plumbing 10 10-28-2011 05:06 AM
Shower Drain Plumbing to very roughed in pipe CompleteBath Plumbing 9 12-09-2010 10:41 PM
ALOT Of Help Needed for Plumbing ~FYE~ Plumbing 4 09-22-2009 01:28 AM
Sewer smell after hooking into plumbing vent daveyd Plumbing 10 08-10-2009 07:25 PM
