#1 |
Rough in valve, can I use Pex?
Remodeling bathroom, and I'm tiling the tub surround and replacing shower tub faucet from and old 1980's delta to a new price pfister. I know I will need to change the rough in valve with the one that came with the new faucet but I was wondering if I could use pex instead of cooper due to the fact that the new valve is much bigger and will require a bit of cutting and resoldering. Is it worth it? Or should I just stay with copper due to it being such a small job? If you think I should go with pex where can I get all the supplies I'll need. My local HomeDepot doesn't have a good supply of pex. I'm from Newberg Or.
#2 |
I blame ProWallGuy
Pex seems to be a decent material for water but like any plastic, its downfall can be the method of joining it to fittings. If you can crimp it, then by all means, do so. If not, stick with the copper. A leak in the wall is no fun in a new bathroom, especially in a tub/shower surround.
Check with your local plumbing inspector to see if you need permits and to see if pex is allowed in your area. You don't want to use something that is not code approved for your area. |
#3 |
Journeyman Plumber
We use pex all the time and recommend it.
#4 |
I blame ProWallGuy
Ron, when used with the proper tools to install, I agree that PEX is an excellent choice. But, this is a homeowner and not another plumber. If they have access to the tools, then use them, but I would not put compression style fittings in an inaccessible location, hence, the copper recommendation.
#5 |
Journeyman Plumber
I agree on the compression fittings, yes here in Oregon which is where he lives, allows pex, he will need to go to a supply house to get the proper fittings, I think HD will rent out the crimper tool.
| Display Modes | |
| ball valve leaking | bwall | Plumbing | 10 | 12-31-2012 08:25 PM |
| Toilet valve replacement? | steve771 | Plumbing | 18 | 07-10-2007 11:50 AM |
| Main valve not working. Water won't turn on! | skellies | Plumbing | 1 | 10-31-2006 03:17 AM |
| Periodic release from (I think) the T&P valve on the water heater | alexz | Plumbing | 3 | 08-15-2006 11:31 AM |
| leaking 1 1/4" Brass Ball Valve | creemore | Plumbing | 2 | 03-11-2005 09:23 PM |
