Rough Underground Plumbing For Basement Bathroom - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-22-2008, 06:11 PM   #1
JTK
Rough underground plumbing for basement bathroom
What is the correct location for the vent tie-in to the underground plumbing? We originally had underground plumbing installed in the basement for a future bathroom, but we are changing the floor plan and need to re-arrange the underground plumbing. The new layout is: a 3" PVC pipe coming off the main sewer (underground) with the toilet at the end. From the toilet end, it is first the tee for the tub drain, then the tee for the sink/vanity drain before hooking up to the main sewer. Is the vent supposed to be between the last tee and the main sewer? Does it matter where the tee is for the vent along 3" pipe?
JTK is offline   Reply With Quote
Old 07-23-2008, 08:30 AM   #2
Long-Time DIYer
Mike Swearingen's Avatar
Yes, it matters where vents are located in relation to the traps that they're venting.
Check with your Building Inspection Department for local codes, permit and inspection requirements for this plumbing work. Then you know that it will be right.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Bathroom rough in shamrock_94 Plumbing 6 07-12-2008 10:33 PM
Basement Bathroom Rough In snowwhite49 Plumbing 2 05-26-2008 09:11 AM
Rough plumbing in basement (PIC) BrntWS6 Plumbing 4 02-26-2008 06:30 PM
Slope for Bathroom Rough in m4larson Plumbing 3 01-27-2008 09:38 AM
Exposed bathroom plumbing? DIYnewby Plumbing 5 09-30-2007 06:41 PM
