Rough-in Specs For Toto Toilet. - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-03-2006, 02:53 PM   #1
747
registered
747's Avatar
Rewards Points: 534
Rough-in specs for toto toilet.
Ron on that toliet link i posted on another thread it said SPECIAL NOTE
Water supply rough-in is wider than standard 5 1/2" rough-in. Consult your builder or contractor.
What does this mean. Would a plumber have to change the pipe in the wall to make that toto toliet work?
747 is offline   Reply With Quote
Old 11-03-2006, 06:13 PM   #2
Journeyman Plumber
Ron The Plumber's Avatar
What they are saying is the water supply stub out from center of toilet needs to be more then 5 1/2", they recommend rough at 8" from center and 4" off floor.
It the stub interfers with the setting of the toilet then yes a change would need to be done.
See spec pdf sheet via this link.
http://www.toiletsthatwork.com/toile...s/CST764SG.pdf
Ron The Plumber is offline   Reply With Quote
Toilet jpark Plumbing 18 01-05-2009 07:12 AM
Advice on commercial toilet install SoCalSwami Plumbing 9 05-15-2008 03:43 PM
Leaking pipe under toilet aprildawn Plumbing 4 01-21-2007 04:32 PM
Shower Body, Toilet Water Supply Rough helpless handyman Plumbing 5 11-06-2006 08:51 AM
Replacing a Toilet dandgluna Plumbing 8 07-10-2006 10:09 PM
