Which Rough-in Shower Valve? - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-29-2012, 10:44 PM   #1
JOATMON
ddawg16's Avatar
Rewards Points: 2,108
I'm ready to order my Delta rough in valve.....so many choices....
Ok...I know I need the one that uses 1/2" copper....but do I need screw stops?
I need two....shower only...
Any other options I should have?
ddawg16 is online now   Reply With Quote
Old 09-30-2012, 11:18 AM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 900
The advantage to screw stops are that you can turn off the valve for servicing while not affecting the other fixtures. Usually the main needs to be turned off for service.
The disadvantage is that your paying for an option that is only used when you service the valve. With a Delta, that will be a long time from now.
Old 09-30-2012, 11:59 AM   #3
JOATMON
ddawg16's Avatar
Well....considering that I have a 'real' ball valve at the front of the house for turning off the water....and a ball valve that allows me to shut off just the back side of the house (leaving one bathroom in operation), then I guess I don't need the screw stops....right?
So...the r10000-UNBXHF
This is the one without the tub outlet....shower only....
One of my next posts will be for 'best practices' on how to mount them.
Old 09-30-2012, 12:20 PM   #4
Ole Wood Worker
BigJim's Avatar
Rewards Points: 760
When you go to buy the valve check the price on each valve, one for tub and one for shower. We just bought a Delta valve for our shower and the one without the tub spout was higher than the one with the tub spout and they are exactly the same valve, the bottom hole has to be plugged for the shower.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
Old 09-30-2012, 12:44 PM   #5
JOATMON
ddawg16's Avatar
I was noticing that....
efaucet has both of them at the same price ($28.92)....Amazon has the HF for about $3 more....
On one shower (my shower), we plan to also install a diverter for a hand wand.....I'm assuming that there is no advantage to useing the UNBX in this type of application?
Need help: Broken stem in Moen shower faucet valve cartridge Learning Lots Plumbing 14 04-06-2015 05:27 PM
Toilet and Shower Rough In Dimensions VikingDinKC Plumbing 16 05-13-2012 01:50 PM
Shower Spider Valve Outlet: Elbows, Braided, ?? yogi_bear_79 Plumbing 6 11-03-2011 10:44 AM
Can't Identify Shower and Tub rough in valve stamped SHWR 7196 and TUB P-P USA help4diy Plumbing 1 11-21-2010 09:06 AM
Best 1/2 inch water shut off valve. Nestor_Kelebay Plumbing 10 07-25-2008 11:16 AM
