Rough-in Radiator Pipe Height Above Floor - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-03-2011, 11:25 AM   #1
Rewards Points: 1,062
Question
rough-in radiator pipe height above floor
what is the typical thickness of carpet and/or hardwood flooring that is calculated in on top of subfloor when determining the length of final radiator nipples rising from the floor? is 3/8-1/2" safe to calc in on top of 3/4" of the subfloor.
thanks
Old 11-03-2011, 11:33 AM   #2
biggles's Avatar
laying a lenght of fins on a 2x4 for the wood floor, and (2) 2x4s for carpeting add up for both wood and carpet the double will be clear enough...better off soldering the nipples on the element runs and drop them down if you have a crawl or basement.pipe it to a mounted sections without the covers on
Closet flange height to finished floor... fitnow Plumbing 7 10-16-2011 10:03 PM
Dryer duct hole thru band joist & floor joist justplumducky General DIY Discussions 12 10-05-2010 12:31 PM
how to fasten plywood to subfloor to even out floor height cmlcsu Flooring 11 11-08-2009 09:19 PM
Changing poly type during hardwood floor refinishing redpen Flooring 17 02-03-2009 06:11 PM
Baseboard trim height from floor billyg Carpentry 6 01-20-2009 10:08 PM
