-   -   rough-in radiator pipe height above floor (http://www.diychatroom.com/f7/rough-radiator-pipe-height-above-floor-122266/)
amakarevic 11-03-2011 11:25 AM
what is the typical thickness of carpet and/or hardwood flooring that is calculated in on top of subfloor when determining the length of final radiator nipples rising from the floor? is 3/8-1/2" safe to calc in on top of 3/4" of the subfloor.
thanks
biggles 11-03-2011 11:33 AM
laying a lenght of fins on a 2x4 for the wood floor, and (2) 2x4s for carpeting :whistling2:add up for both wood and carpet the double will be clear enough...better off soldering the nipples on the element runs and drop them down if you have a crawl or basement.pipe it to a mounted sections without the covers on:wink:
