Rough-In Question...NEED HELP - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-08-2012, 07:15 AM   #1
Attached are the pictures of my roughed in basement bathroom. Pipe (A) is 18 inches from the backwall, 20 inches from pipe (A) to pipe (B), and pipe (B) is 18 inches from pipe (C). I am assuming that (B) is the sink drain and (C) i know is the toilet. What i dont understand is how is this going to work with all these pipes so close together. the way my floorplan is, I want the toilet to face the left of the picture, and i just cant figure out how everything will fit in. Please Help. I start framing Saturday! thanks.
Rough-In Question...NEED HELP-2012-03-07_21-06-59_73.jpg   Rough-In Question...NEED HELP-2012-03-07_21-07-10_526.jpg   Rough-In Question...NEED HELP-2012-03-07_21-07-27_283.jpg
fax6202 is offline   Reply With Quote
Old 03-08-2012, 11:46 AM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 664
A = tub
B = toilet vent/lav waste. Use a trap arm to move the lav to your desired location
C = toilet
So A & B will be in a plumbing wall. The center of C should be a min. 12.5" from the face of the plumbing wall
It looks like you have a pit for a sewage pump that your future bath drains to. Of course that needs a pump and plumbing (and vent) as well.
The Following User Says Thank You to TheEplumber For This Useful Post:
jaydevries (03-08-2012)
Old 03-08-2012, 12:10 PM   #3
thank you for the response. you mentioned that A and B would be in a plumbing wall. how does that factor into my framing. Do i need to frame an interior wall within the bathroom walls? Thanks.
Old 03-08-2012, 12:45 PM   #4
Not so new
12penny's Avatar
Rewards Points: 520
That is the bathroom wall.
12penny is offline   Reply With Quote
Old 03-08-2012, 02:19 PM   #5
Plumber
Rewards Points: 664
Yep, unless you want to move the ground work, that wall will be the wall your tub valve is in. You're lav is against it too, as well as the back of the toilet. Not too many options left- pretty cut and dried rough in so far. You might want to rethink you're floor plan
Old 03-08-2012, 03:10 PM   #6
Rewards Points: 636
i would first start out with what size is pipe A and if it has a trap on it by pouring water in it and then looking for standing water in pipe then deciding on plumbing fixtures and getting rough in dimension for them to make sure wall locations are correct. also as mentioned by others i agree with fixture locations for each pipe, do not forget about venting, and if that is a sewer pump pit it will have to be finished to pump out bath sewage
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
rough framing for an exterior door (not prehung) measurement question graysqwrl Building & Construction 5 08-15-2011 08:51 PM
what to do for plumbing rough inspection? red86yota Plumbing 5 09-12-2010 04:39 PM
Rough Opening issues for interior Pre-hung door get2bill Carpentry 3 04-04-2009 07:27 AM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
hrv question indep HVAC 3 07-17-2008 10:39 PM
