Old 01-16-2011, 09:47 PM   #1
Rough plumbing slab before septic
I have a real quick question.
I am planning to build a 45'x55' building on my grandparents property. I'm going to use it as storage for a couple years and once I'm ready the property will be divided and this will be converted for use as a residence
My question is can I have the plumbing in the slab roughed in and capped off outside the slab? I obviously won't have the septic installed and won't until I'm converting to a house. I will be able to figure the best location for the system though.
dcase is offline   Reply With Quote
Old 01-16-2011, 09:58 PM   #2
Persona Non Grata
VIPlumber's Avatar
Shouldn't be a problem. Just leave a few extra feet or more outside the slab and glue on your caps. Then you'll have plenty to extra to cut into.
VIPlumber is offline   Reply With Quote
Old 01-16-2011, 10:52 PM   #3
That is great news! Thanks for the reply.
what to do for plumbing rough inspection? red86yota Plumbing 5 09-12-2010 05:39 PM
Concrete slab to foundation work tntgarv Building & Construction 3 02-28-2010 01:23 PM
running plumbing through slab jod11 Plumbing 3 09-29-2009 04:58 PM
Basement bathroom rough in plumbing ferris13 Plumbing 5 09-28-2009 11:06 AM
Plumbing Under Slab (New Construction) zzyzx Building & Construction 9 11-22-2008 01:41 PM
