Rough In Plumbing Pre Test? - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-20-2012, 06:47 PM   #1
Rewards Points: 101
Rough in plumbing pre test?
I've finished my DWV for my rough in inspection and Im not sure how to test for leaks. I bought these little yellow and white caps that just sort of press into the ends of my ABS. Do I just cap all of them and then pour water into my vent on the roof? Seems like there must be a better way. What do those in the know do? Thanks, 1
1dumbquestion is offline   Reply With Quote
Old 01-20-2012, 06:58 PM   #2
Master Plumber
Javiles's Avatar
Rewards Points: 996
Depending on your local code requirements, and what you are testing and how its set up. Under our code, test tee at the new to old transition plugged and a five foot water column, anywhere in the system. All new piping must be under test. 30 min, on the test.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
The Following User Says Thank You to Javiles For This Useful Post:
plummen (01-20-2012)
Old 01-20-2012, 08:12 PM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 924
Be sure the yellow test caps are glue. Don't just push them in.
My area requires a 10' head of water or 5lbs of air pressure. We opt for air when it's below freezing but water is the way to go- you can see your leak
What is the standard method of water pressure test for shower plumbing please? Andy21 Plumbing 10 10-28-2011 04:06 AM
Home owners plumbing test Painterabroad Plumbing 0 10-02-2011 07:48 AM
Testing new plumbing with air pressure Niffumdutz Plumbing 22 06-19-2011 03:35 AM
basement plumbing rough in - what are these pipes? skypilot84 Plumbing 1 10-12-2010 11:59 PM
Sewer smell after hooking into plumbing vent daveyd Plumbing 10 08-10-2009 06:25 PM
