Rough In Not Aligning With Vanity - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-06-2008, 09:51 AM   #1
jelly's Avatar
Rewards Points: 330
Rough in not aligning with vanity
Since it is an exterior wall, the water supply lines come up through the floor. I have about 4" of space in the vanity base to work with so I plan putting in some elbows 1" off the tile and simply come up through the bottom of the vanity. I assume this is the best solution.
The drain and vent lines enter the room from the wall and run right into the drawers. Should I rip open the wall, add an elbow behind the sheet rock and come out centered in the sink?
What are my options?
jelly is offline   Reply With Quote
Old 09-06-2008, 11:01 AM   #2
I think doing as you are already thinking would be the best solution for the drain and vent but if you already have clearance on the water lines why put on elbows.Come up through the base pue a shut off valve in and connect flexable supply lines to it
clasact is offline   Reply With Quote
Old 09-06-2008, 11:57 AM   #3
jelly's Avatar
Rewards Points: 330
As far as the copper lines, the two you see in the picture are fine as they are, the other two are underneath the drawers.
I probably should have ripped open the wall and inspected the drain/vent lines before I posted. Since I am only 2 inches off center to the drain, I am going to cut the abs above and below the "T" , reconnect with slip couplings and enter the bathroom from the wall at an angle.
I think this is the best solution.
Old 09-06-2008, 04:05 PM   #4
Send a message via AIM to Marlin
That will work fine. Their is no such thing as a a PVC slip coupling though, you need to have the play in the pipe.
Marlin is offline   Reply With Quote
Old 09-06-2008, 06:28 PM   #5
jelly's Avatar
Rewards Points: 330
Thanks Marlin. Couplings have tits inside that prevent you from sliding the pipe all the way through. I thought they made couplings without the tits?
Old 09-07-2008, 01:11 AM   #6
Not for PVC.
shower rough in frusteration! Lmiller Plumbing 5 03-13-2008 12:24 PM
Vanity light bathroom drill hole concern sooner2k1 Plumbing 1 01-10-2008 07:04 AM
Bathroom vanity rough in diyer4162 Carpentry 13 11-09-2007 05:36 PM
Machining Marble SideSplash for Vanity jombres Remodeling 4 12-03-2006 05:38 PM
Adding outlets behind bathroom vanity? Carwen Electrical 3 08-14-2005 09:10 PM
