Rough In Mysteries - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree1Likes
  • 1 Post By jlhaslip
Old 01-06-2017, 07:41 AM   #1
Rewards Points: 8
Rough in mysteries
Hello everyone,
I finally decided to add a bathroom to my basement and luckily I had the rough-in plumbing included. I am a little confused because I see the toilet rough-in and the sink rough-in plumbing but I only have one more which is a 4" pvc coming from the ground(picture attached) but I am confused on how to attach this to a shower base? do I have to cut it and buy an adapter(4" to 1 1/2") or do I have to break into the concrete and convert it to a p-trap? any advice would be appreciated.
Thanks,
Job
job1243 is offline   Reply With Quote
Old 01-06-2017, 09:14 AM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 564
Re: Rough in mysteries
Welcome to the forum job1243. Can you give us a shot from further back so we can see all the rough in? 4" is not normal for a shower rough in. Usually there is a blocked out section of slab with a 2" pipe.
Edit: are you sure thats not the toilet?
Old 01-06-2017, 12:27 PM   #3
Rewards Points: 13,456
Check to see if the center of that 4" pipe is a little over 12" from the wall.
If it is that's the toilet stub out.
Showers are always 2" not 1-1/2, or 4" as you suggested.
Old 01-06-2017, 02:06 PM   #4
Rewards Points: 8
I was able to clear all the clutter inside of it and saw that there was another pipe in it, does this help identify what it could be? I'm hoping its for a shower because the other drain in the ground(Second pic) looks like it is for the drain.
Rough in mysteries-20170106_124026.jpg   Rough in mysteries-20170105_111306-5-.jpg
Old 01-06-2017, 02:35 PM   #5
Rewards Points: 268
The 2nd pic is the closet flange to mount a toilet on.
Apparently they used a 4" pipe as a sleeve. That sleeve would not be helpful at all for hooking up a tub, but the drain pipe looks to me like it might be 1 1/2" which is no good for a shower drain.
Can you post a wide angle shot of the entire bathroom set?
BlackTiger is offline   Reply With Quote
Old 01-06-2017, 07:48 PM   #6
Any idea on how the so called plumper was that did this job?
None of that work looks right.
Old 01-06-2017, 10:37 PM   #7
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 2,480
Some locals, at least in Cali., require a sleeve through SOG. It is supposed to be filled/sealed after hookup.
MTN REMODEL LLC is online now   Reply With Quote
Old 01-06-2017, 10:39 PM   #8
Run a snake down... you should be able to feel/tell if a P trap is there.
Old 01-10-2017, 12:04 PM   #9
Rewards Points: 8
Thanks for all the suggestions everyone, attached is an overview of how the bathroom is set up. I'm pretty sure that the hole in the floor is the toilet flange and the 1 1/2 inch pipe on top of that is the drain for the sink, the only thing that is still a mystery is that 4 inch white pipe with the 1 1/2 inch pipe in it coming from the ground, I even got a plumber who had no idea what it was. Trying a snake to see if it has a p trap is a great idea I will try that, thanks.
My only challenge is the shower drainage, I'm trying not to break the concrete. What im thinking of doing is Teeing into the 2" drain pipes behind the toilet flange in the pic and building a shower stall on a 6" elevation and run the plumbing under that for the shower.
Old 01-10-2017, 12:16 PM   #10
jlhaslip's Avatar
Rewards Points: 1,538
I had a house with an elevated shower stall and, believe me, it sucked.
Break out the concrete and do it right. Drill a series of holes along both sides of the trench and get a demolition tool. It really is easier and less work than you imagine.
MTN REMODEL LLC likes this.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is online now   Reply With Quote
Old 01-10-2017, 10:35 PM   #11
Rewards Points: 268
Considering the crooked pipes and the closet flange, the original plumber may not have been the most careful on the underground work. Possibly there is a tub or shower box which was placed too low and a skin of concrete is hiding it. I still have no idea why the sleeve, though. Is the inner pipe capped or open? If it's open and there never been a sewer smell from it, it might not even be attached to the main sewer..
Old 01-11-2017, 04:43 AM   #12
Rewards Points: 8
yes, it is capped.
Old 01-11-2017, 05:51 AM   #13
MEASURE ONCE, CUT TWICE
123pugsy's Avatar
Rewards Points: 954
I would say to cut the 4" sleeve flush with the floor so you can start to investigate. You could drill a hole in the cap to run your snake thru. If you get some nice perfume smell coming up usually accompanied with a breeze, you're probably good. Check for the trap and Bob's your uncle.
1-1/2" will work for a shower. It's accepted in our area for a single shower.
I don't believe you're at the trench the floor or start building elevated boxes stage yet.
Pugsy.....my project: Total House Rebuild Bungalow to Two Story
123pugsy is online now   Reply With Quote
Rough in valve function question spacepunch Plumbing 11 01-04-2017 09:50 PM
Very noob question about rough opening on door sonnaps Building & Construction 44 09-08-2015 07:28 PM
Toilet and Shower Rough In Dimensions VikingDinKC Plumbing 16 05-13-2012 01:50 PM
Basement Toilet Rough In - Help atm Plumbing 3 06-06-2009 11:04 AM
Replace a 10" rough in toilet with a 12" rough in Opie46 Plumbing 3 05-16-2009 11:27 AM
