Rough-in Heights - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-24-2012, 06:18 AM   #1
JOATMON
ddawg16's Avatar
Rewards Points: 1,826
Rough-in Heights
I came across this in a search (yea, I actually do that before asking stupid questions)
Lav water = 21" on 8" centers
Lav drain = 19"
Toilet water = 6" off center and 6" high
KS water = 21" on 8" centers
KS drain = 15"
Laundry Tub water = 12" on 8" centers
Laundry Tub drain = 12"
Washer Box = top at 42"
Is this in line with what most of you do?
Old 05-24-2012, 06:27 AM   #2
DIY staff
Rewards Points: 7,174
That's a handy little guide---
Old 05-24-2012, 09:23 AM   #3
Doing it myself
Alan's Avatar
Rewards Points: 2,086
It's pretty close to what we do and should work for most. . . . .
If you're buying some exotic non standard toilet be sure to check the rough in specs for the water line, otherwise your 6 x 6 rough in location may not work.
Journeyman Plumber
Old 05-24-2012, 09:38 AM   #4
Plumber
TheEplumber's Avatar
Rewards Points: 682
Minor points but, I'd add to the toilet-- water stub out on the left side
Also preplan your kitchen sink layout. If 2 compartment sink is being used you should try to line up to one of the bowls so you can use a end out continuous waste. Makes for an easy, clean trim job
Old 05-24-2012, 07:34 PM   #5
Doing it myself
Alan's Avatar
I messed that one up once. How embarassing.
Journeyman Plumber
Old 05-24-2012, 07:35 PM   #6
Doing it myself
Alan's Avatar
We go 8 inches off center toward the side nearest the dishwasher.
Journeyman Plumber
Old 05-24-2012, 07:40 PM   #7
Plumber
Rewards Points: 682
You're not alone
Old 05-24-2012, 07:46 PM   #8
DIY staff
ADA handicap toilets have either left or right flush handles--and guts---handle must be away from a side wall--so toilet feed could be on the right--This is for commercial work but might occur in a home--
Old 05-25-2012, 09:31 AM   #9
JOATMON
ddawg16's Avatar
One that is missing is the toilet drain rough in.....
I measured the toilet in the existing part of my house....12" to the center of the hole...I recall a thread where guys were talking about 12" to the back of the pipe....that would put it a bit far from the wall.
Old 05-26-2012, 12:02 PM   #10
In a little over my head
Rewards Points: 706
12" from the wall for the toilet drain. but don't forget the 1/2" for the drywall, so 12.5" rough.
ratherbefishing is offline   Reply With Quote
Old 05-26-2012, 12:08 PM   #11
+ wall finish, ie - tile.
VIPlumber is offline   Reply With Quote
Toilet and Shower Rough In Dimensions VikingDinKC Plumbing 16 05-13-2012 01:50 PM
Basement Rough in PSULion55 Plumbing 1 02-06-2010 12:44 AM
Basement Toilet Rough In - Help atm Plumbing 3 06-06-2009 11:04 AM
Replace a 10" rough in toilet with a 12" rough in Opie46 Plumbing 3 05-16-2009 11:27 AM
