Which Rough In Is For Which Fixture? - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-29-2012, 03:53 PM   #1
Which rough in is for which fixture?
I am finishing my basement and the plumbing for the bathroom was roughed in by the builder but I'm not positive which one is for the toilet and for the shower or sink.. I have some pictures if maybe somone could identify which is which and also how far away should each of them be from the wall. Oh and as for the PVC pipes one says 4" on the cap and the other says 2".. The black one doesn't say
Thanks, Nate
nateyro is offline   Reply With Quote
Old 01-29-2012, 04:01 PM   #2
Rewards Points: 12,882
The 4" one is the toilet, the black one looks it's for a tiled shower pan and the 2" would be for the sink.
But there lay out makes no since. Your missing some walls. No one gave you a layout when you bought the house? Can you call the plumber?
The toilet needs to be 12" from the center of the drain to the finished wall (minus the baseboard)
plummen (01-29-2012)
Old 01-29-2012, 04:14 PM   #3
Ok thanks.. I'm not sure who the plumber is I bought the house not that long ago but it is about 15 years old..I had kind of planned my remodel around the black one being the toilet and the 4 in being the shower but I took the cap of the black one and measures and the pipe is about 5 1/2 inches.. I'll take a picture of it open and let me know what you think..and like you said the layout does seem wired because it's forcing me to build a awkward shaped bathroom... Thanks again
Old 01-29-2012, 04:30 PM   #4
Rewards Points: 616
the 4 " is for toilet. 12" center from back wall and minimum 15" side wall A.D.A. which is desired is 18". the 2" is for sink it could also be a wet vent for shower depending on how it is plumbed,pipe should come out off wall at around 16 to 18" high for sink. the black looks like a shower flange take off cover and check for trap. i see a pipe in already framed wall i am assuming that is the vent for toilet. so you can tie in to it for sink vent or use a air admittance valve under sink cabinet. this is what it looks like to me remember this is my opinion from what i see. also what does it say on black cover.
jaydevries is offline   Reply With Quote
Old 01-29-2012, 04:37 PM   #5
Plumber
TheEplumber's Avatar
Rewards Points: 356
Is that a flapper inside the black one? I can't imagine a shower in front of the door- maybe a backwater valve
Old 01-29-2012, 04:44 PM   #6
A shower would only need a 2" drain but what made me think the black one was the shower even though it looks bigger then 2" is the cut out in the floor around it. Looks like it was boxed in for the pore leaving room to install the trap, then filled in after with concrete.
Old 01-29-2012, 05:00 PM   #7
Plumber
Rewards Points: 356
I see that now- good eye. But I still think its a valve. Maybe it was installed after the floor pour. It lines up with the w.c. too. Wonder what the cap says
Old 01-29-2012, 05:01 PM   #8
Rewards Points: 616
some thing else just thought of is to check 2" for trap in floor that could be for shower and sink could be placed on already framed wall with drain armed over to pipe in already framed wall. or may be just plumbed for half bath. it would be easy to turn into full bath though by breaking concrete around 2" and adding trap
Old 01-29-2012, 05:14 PM   #9
Rewards Points: 616
backwater valve seems right for black square look at link to compare http://www.plasticoddities.com/bwv.htm
good eye e plumber
Old 01-29-2012, 06:02 PM   #10
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Whats that lonely looking piece of pvc over there inside of wall?
I think the bathroom is roughed in to sit the other way,with sink on outside wall and w.c and shower side by side facing other wall.
I think that backwater valve or whatever it is is supposed to be outside of room
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 01-29-2012, 07:16 PM   #11
Msradell's Avatar
Rewards Points: 90
That's exactly how it looks to me too. It looks like that PVC on the wall also goes up which would make it the vent which obviously would be needed.
Msradell is offline   Reply With Quote
Old 01-29-2012, 11:43 PM   #12
That black thing is just weird. I'm not familiar with back water valves so I have to ask if they make a trim ring for it?
It looks to me from the pictures that this was intended to be a half bath. You could always add a line for a shower if you like. Is this a sub floor or a slab on grade house?
russplmb2 is offline   Reply With Quote
Old 01-29-2012, 11:55 PM   #13
Plumber
Rewards Points: 356
Usually they are installed flush to the floor. I've had to pull carpet to find them. This one appears to be an after thought- looks like saw cuts around it. UPC requires that they are installed on fixtures that are below the elevation of the next downstream manhole of the city main- sewer will overflow the manhole before backing up into the basement. The fixtures upstairs should ideally not on the valve.
Old 02-01-2012, 01:34 PM   #14
Rewards Points: 616
so what is the black cover did you find out
Installing ceiling fixture with a metal junction box Romanuke Electrical 12 03-20-2011 03:37 PM
Hanging an overhead fixture jbcurrier Electrical 8 11-25-2010 12:19 PM
Installing One Light Fixture Causes Another Not To Work pythagras Electrical 2 07-02-2009 09:15 PM
double-ended halogen fixture bulbs stop working watt-ever-ny Electrical 6 11-20-2007 06:25 PM
Old house, new light fixture, too many wires Persephonee Electrical 3 01-15-2007 09:58 AM
