Rough Bathroom Sink Drain - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-08-2014, 08:12 PM   #1
Trucon01's Avatar
Rewards Points: 510
Rough bathroom sink drain
Hi All,
I'll be tying into a 2" vent for my sink drain, but have a couple questions.
1.
How high up do I put the sanitary tee from the floor? I've seen anywhere from 18-20".
2.
Which method is preferred / best?
a. Use a 2" x 2" sanitary tee and then a 2" to 1.5 reducer on the stub out?
b. Use a 2" x 1.5" sanitary tee and then a 1.5 to 1.25 reducer on the stub out?
The attached picture is not mine, but my set up will be exactly the same.
Basement Demo started Jan 2012: View my basement progression!!!
Bathroom demo started Feb 2013: View my bathroom progression!!!
Trucon01 is offline   Reply With Quote
Old 03-08-2014, 08:54 PM   #2
1) If there's going to be a vanity/cabinet base, then it's six of one and half dozen of the other. If it's a pedestal or console sink, then follow the rough-in specs that come with the sink.
When I was an apprentice, the master I worked for wanted them all at 18". I tend to put them in a little higher now because more and more cabinets seem to have a drawer on the bottom which pushes the "floor" inside the cabinet up a few more inches.
2) Use a 2" x 1-1/2" Tee off the vent. Stub out in 1-1/2"; your trap should also be 1-1/2". Use an 1-1/2" x 1-1/4" Trap Adaptor to connect the tailpiece to the trap.
Ishmael is offline   Reply With Quote
The Following User Says Thank You to Ishmael For This Useful Post:
TheEplumber (03-08-2014)
Old 03-08-2014, 09:12 PM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 564
Pretty much the same for me.
20" above the floor works great on standard vanities. For 36" tops it'll take a tailpiece extension but that's no big deal
Waters I put 2" above the waste, @ 6" or 8" spread
Old 03-09-2014, 09:42 AM   #4
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,192
If that 2" vertical pipe you are tying into is truly a vent for fixtures on a lower floor, you should not be using it as a drain.
Coastal South Carolina
Removing bathroom sink drain plug (glued abs p-trap) ? westbank Plumbing 11 09-06-2013 03:03 PM
Running water does not go down in upstairs bathroom sink :( dnharp Plumbing 3 02-17-2013 04:37 PM
Bathroom sink drain pipe on the side of the wall amandanory Plumbing 7 11-17-2012 10:27 PM
Seeking help with clogged bathroom sink drain dwlodyka Plumbing 20 03-14-2012 10:36 AM
Double Bowl Kitchen Sink Drainage Problem PeteW Plumbing 16 09-05-2011 09:41 AM
