Rough-in Bathroom Help? - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-06-2011, 11:32 PM   #1
Rough-in bathroom help?
I need some help. We had a split entry house built with an unfinished first floor. The bathroom was to be roughed-in. I am trying to understand what the true meaning of roughed-in is. I thought it meant to have the pipes ran so that I can finish the bathroom later. All the bathroom has is a pipe for the drain with a one square foot opening in the concrete slab and two vent stacks coming up about 1.5 feet above the floor. Does roughed-in mean that the water pipes to the vanity, toilet and shower should all ready be ran?
Davidqualls is offline   Reply With Quote
Old 02-06-2011, 11:44 PM   #2
Experienced
Jackofall1's Avatar
Unless you were specific the builder will run the drains only, so you don't have to bust up the floor, at least that has been my experience.
Old 02-07-2011, 09:15 AM   #3
Rewards Points: 135
Was there a preplanned design for the bathroom that the builder could work off of? If not, how would he know where to run anything at all?
wease is online now   Reply With Quote
Old 02-07-2011, 11:25 AM   #4
Rewards Points: 3,130
I have built or bought 10 houses over the years, most having some unfinished portion like for a bathroom. None of them had any more of a rough-in than what you describe. That's all the inspector expects to see for a rough-in.
Basement bathroom rough in efrobert Plumbing 2 06-23-2011 04:54 PM
Basement bathroom rough in plumbing ferris13 Plumbing 5 09-28-2009 10:06 AM
basement bathroom rough in - framing questions twobabieslater Building & Construction 2 12-29-2008 02:56 PM
Bathroom rough in shamrock_94 Plumbing 6 07-12-2008 10:33 PM
Basement Bathroom Rough In snowwhite49 Plumbing 2 05-26-2008 09:11 AM
