-   -   Rough in Bathroom (http://www.diychatroom.com/f7/rough-bathroom-166066/)
oodssoo 12-09-2012 08:20 PM
Rough in Bathroom
6 Attachment(s)
Hello all.
I have a basement project that will involve finishing a bathroom (later the kitchen). I have attached 8 pictures illustrating what all I have to start from.
To encourage the broad range of help from you all, I left my post purposely general but with some specifics. With the help of the attached photos, I would like to know the followings:
1) There are 3 metal bars that look like gound terminals at each of the drains. What are these?
2) I would like to turn the sink drain so I can have the drain pipe come out of the wall rather than the way it is right now. What do you recommend and how would you plumb this?
3) I would like to be able to run washer, kitchen sink, and dishwasher of the basement to the same drain at the bathroom vanity sink. How would I do this?
Thank you in advance.
ben's plumbing 12-09-2012 09:43 PM
those metal pipes look like support stakes to hold piping till concrete....they are too high.....could just cut off....plumbing for tub is wrong no box to hook up tub drain and i don't see tub vent...drain in wall for sink looks wrong also after tub is in...and commode...looks like no room for vanity...imo ben sr
TheEplumber 12-09-2012 09:49 PM
199 Attachment(s)
Originally Posted by oodssoo (Post 1069817)
Hello all.
I have a basement project that will involve finishing a bathroom. I have attached 8 pictures illustrating what all I have to start from.
1) There are 3 metal bars that look like gound terminals at each of the drains. What are these?They appear to be rebar to hold and mark the pipes. They are not needed. The one at the toilet is problematic
2) I would like to turn the sink drain so I can have the drain pipe come out of the wall rather than the way it is right now. What do you recommend and how would you plumb this?Not sure your intent but the arm for the sink can be turned and pointed down the wall. Simply cut the pipe and use couplings
3) I would like to be able to run washer, kitchen sink, and dishwasher to the same drain at the bathroom vanity sink. How would I do this?I don't see this happening from the floor above
My answers are in bold print
oodssoo 12-09-2012 10:12 PM
1) plumbing for tub is wrong no box to hook up tub drain and i don't see tub vent... Thought the tub would just get the ptrap and the vent would simply be the overflow pipe?
2) drain in wall for sink looks wrong also after tub is in...and commode...looks like no room for vanity... That's why, for the vanity, I would like to turn the drain pipe to run through couple of the wall studs and then out at the back of the vanity. In doing this, I then will have room. (see new photo with yellow lines)
joecaption 12-09-2012 10:19 PM
There just is no "standard" location for a tub drain. Set in concrete like that there's 0 adjustment and no access to line up the drain.
oodssoo 12-09-2012 10:24 PM
joecaption,
I have added a photo with yellow lines to indicate the location and layout of the bathroom that I thought would work best.
But you are right... it's a pain in the butt that the tub drain is burried in the concrete! Why don't they just leave a cut-out so us DIYers don't have to chip the concrete just to install a stinkin' ptrap?! OR if they could have just installed a ptrap to begin with?!
But I must ask those that could help me with suggestion to chime in... I don't mean to get carried away for a moment... :)
ben's plumbing 12-09-2012 11:29 PM
Originally Posted by oodssoo (Post 1069938)
joecaption,
get out your tape again..if tub is there what about commode measure from back wall out 25-28 inches...tub is 30" ...how wide is room..thats the space you will have between front of commode and tub....ben sr
TheEplumber 12-09-2012 11:43 PM
199 Attachment(s)
Based on the location, I thought that was a shower trap- not a tub. What size is the pipe? If it's 2" then make it a corner shower- unless your set on installing a tub
oodssoo 12-09-2012 11:47 PM
It's going to be about 6'6" by 8'.
It's a 2". Why are you suggesting a corner shower? Is it because of the 2"? Please elaborate.
TheEplumber 12-09-2012 11:56 PM
199 Attachment(s)
Tubs use a minimum 1.5" drain and trap. Also they tend to be roughed in with a box as you alluded to and also closer to the wall. A 36"x36" shower needs a 2" drain centered 18" off each wall- similar to yours. You can use a fiberglass unit or build your tile unit. As it is now, you've got a fair amount of concrete to remove- doable but a shower would be my choice
oodssoo 12-10-2012 12:15 AM
I see. Your logic is based on the location and the size of the pipe... Regardless, it seems to be that either way would still be doable.
A tub serves both purposes - shower or relaxing bath.
I guess it would be a small challenge, but a reducer would take care of the 2" pipe vs. 1.5" pipe, right?
TheEplumber 12-10-2012 12:25 AM
199 Attachment(s)
Correct. you'll end up with something like this image. Notice the relationship to the end wall. I would use a 2" trap- reduce the top of it to 1.5" to receive the tub waste & overflow assembly. The image also shows a vent serving the tub- You don't have one but which concerns me a little. It must be vented somehow in order to pass the original inspection
oodssoo 12-10-2012 12:28 AM
Are you suggesting there should be two vent pipes - one for lav and one for tub? There is already one, I know, over the lav drain.
TheEplumber 12-10-2012 12:37 AM
199 Attachment(s)
Sort of. Put 4 plumbers on a pipe lay out and you'll get it done 4 different ways- all will be legal as defined by code.:)
Most likely, all 3 fixtures are served by the 1 vent, which is not normal in my parts but is done occasionally. Your probably just fine and I'm overly concerned.
oodssoo 12-10-2012 12:41 AM
Well, my original question was also about the vent for the tub drain... I thought the tub drain vents through its overflow? Isn't that correct?
Also, what's the likelihood that there is already p-trap installed and I just don't know it...? How can I test this theory?
