Rough In Basement Finish - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-14-2013, 01:02 PM   #1
Rough in basement finish
I am working on my plan to finish my basement. The builder roughed in the drains for a bathroom but it is in a terrible location and I decided to not build one at this time. Obviously I cut out the concrete and cap these lines but what about the line going up. Is that supposed to be a vent for the toilet once installed?
Rough in basement finish-image-633143368.jpg   Rough in basement finish-image-1299560188.jpg   Rough in basement finish-image-2366217568.jpg
RegLearning is offline   Reply With Quote
Old 10-14-2013, 01:20 PM   #2
MarginallyQualified
Rewards Points: 2,464
Originally Posted by RegLearning View Post
Obviously I...
what is obvious?
Toilets (installed in well planned locations) don't get vents.
Back to the start... if you really don't want to install a bathroom at this location and if that means the exposed pipes will be in the way of some other use for the space... if/when you break up the floor you will/should find that the several pipes you see now will ALL route to a common point. That's where the cap goes.
Heat for a basement with Pellt Stove on Main Floor magnum44 HVAC 1 11-20-2011 08:55 AM
to finish a basement height wellcraft Building & Construction 7 11-23-2010 09:01 PM
Basement Finish with Projector and Media Cabinet C_J_GO Project Showcase 8 08-15-2009 10:35 PM
Basement Toilet Rough In - Help atm Plumbing 3 06-06-2009 11:04 AM
Basement Bathroom Rough In snowwhite49 Plumbing 2 05-26-2008 09:11 AM
