Rough In 3 Piece Washroom In Basement - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-18-2012, 02:57 PM   #1
Rough in 3 piece washroom in basement
Looking at my basement 3 piece rough-in I am unsure which pipe is which and why they placed it the way they did. The vent pipe seems awkwardly close to the 4" toilet drain and both pieces well away from the wall. I suppose the builder thought shower in corner by wall with sink next to it and then toilet?
JPishztam is offline   Reply With Quote
Old 04-18-2012, 03:01 PM   #2
figured it out
Old 04-18-2012, 04:14 PM   #3
MarginallyQualified
Rewards Points: 2,464
Originally Posted by JPishztam View Post
The little text illustration didnt' come out correctly:
Take a few digital pics and attach them here.
But regardless of what you have now if you want something different...
all you need is a jackhammer and some fittings.
Old 04-18-2012, 04:24 PM   #4
Homerepairguy's Avatar
Rewards Points: 998
---------------------sink--- <-- wall on this side to keep boiler area seperate
---------------------toilet--
------door------------------
Hi JPishztam,
When doing text drawings, try using the "code" option and the "lucida console" font. The code option is the "#" icon above the text box when you are keying in your text. The lucida console font is a monospaced font. Courier is also a monospaced font. Here's an example using the lucida console font:
Code:
              |sink|
              |toilet|
==| door |==============
Always select the font before you start keying in the text drawing.
Typing the drawing and then highlighting the text and selecting the monospaced font later does not always result in correct spacing.
EDIT:
JPishztam,
I retract my statements above. Although the technique I described works fine on my desktop PC, another poster said the text drawings I made in another thread were not proper on his computer. I checked them using my laptop and indeed, the forum software does not display them properly on my laptop either.
Sorry for wasting bandwidth,
HRG
Last edited by Homerepairguy; 04-22-2012 at 11:29 PM. Reason: Retracting my post as it does not always work.
Homerepairguy is offline   Reply With Quote
The Following User Says Thank You to Homerepairguy For This Useful Post:
JPishztam (04-19-2012)
Old 04-18-2012, 04:34 PM   #5
Ravenworks's Avatar
Ravenworks is offline   Reply With Quote
Old 04-19-2012, 10:06 AM   #6
I will embed the vent line into the wall which would take me to within the proper distance from toilet line to wall for toilet.
Heat for a basement with Pellt Stove on Main Floor magnum44 HVAC 1 11-20-2011 08:55 AM
Basement bathroom rough in........ Mills314 Plumbing 8 06-09-2011 09:22 AM
New rough opening to basement - spiral staircase benjamincall Building & Construction 8 07-16-2010 05:53 PM
Rough plumbing in basement (PIC) BrntWS6 Plumbing 4 02-26-2008 06:30 PM
Cellar to rough basement? javamom Remodeling 1 06-27-2006 04:23 PM
