Rotten Heater Anode Rod - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-20-2012, 01:24 AM   #1
Rewards Points: 35
Rotten heater anode rod
For my water heater, I finally got a long enough breaker bar to remove the anode rod to check it, and all I have is a plug with rust in the middle. The rod has corroded and fallen off the plug. I reinstalled the original plug (and it is very likely the original...in my 4 years here it has not been replaced). I will wait until I have a replacement on this 1989 Mor-Flo heater. The heater still works fine. Is it recommended or worthwhile to try to fish out whatever is left of the rod it when I again work on this heater? I have never heard any rattling in the heater. When I drained some water to remove the anode, I saw no obvious sediment. If I do try fishing, any suggestions on how?
EdLank is offline   Reply With Quote
Old 03-20-2012, 01:26 AM   #2
Rewards Points: 12,808
Not going to happen, just replace it and move on to the next project.
Old 03-20-2012, 07:25 PM   #3
Rewards Points: 1,418
Leave the remains of the rod behind in the tank and install a new rod as soon as possible.
Old 03-20-2012, 10:36 PM   #4
Master Plumber
Javiles's Avatar
Rewards Points: 984
Wow ,, Mor Flo water heaters I was the factory rep in Miami in the 90s for a cheap heater they were not bad, 1989 ? I would say change the heater, anything after 15 years on that tank is borrowed time
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 03-21-2012, 07:13 AM   #5
Rewards Points: 1,214
TIP, to anyone reading this that has to to remove an anode rod use a impact wrench with a 1 1/16 socket. Borrow one if you have to.
COLDIRON is offline   Reply With Quote
Old 03-21-2012, 12:16 PM   #6
Rewards Points: 35
I think a breaker bar is a better choice. The extreme vibrations of an impact wrench are more damaging to something that is corroded or coated with deposits.
However, when just moving into a house, damaging a working water heater looses kudos points with one's spouse. I just took too long getting back to it.
Old 03-21-2012, 12:54 PM   #7
" It's not a better choice".
water heater drip kdange1 Plumbing 6 10-29-2014 06:26 PM
Pilot on Williams millivolt wall heater goes out every 8 to 16 hours wornways HVAC 30 06-22-2011 04:29 PM
Replace hot water heater anode? Mr_allthumbs Plumbing 12 02-16-2011 09:39 PM
Bradford White Water Heater Anode Replacement pgs Plumbing 3 05-04-2010 06:58 PM
Sign of deteriorating water heater anode? Frank O Plumbing 18 02-28-2010 01:52 PM
