Rotten Galvanized To PVC?!?!? - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-14-2010, 12:20 PM   #1
Rotten Galvanized to PVC?!?!?
Long time reader...Second time Poster.
I moved into a Brick Bungaloo in October or last year. I recently had to replace the water shut off valve while doing a basement finishing project. While doing the shut ff replacement, I found I had to replace the unions and the 4in nipple because the galvanized pipe threads had been worn away, and eventhough it is a 3/4 inch galvanized pipe the water passage is MAYBE 1/4inch, less in some areas.
I want to swap out the Galvanized for Schedule 40 PVC. I put a post in the Electrical forum about moving my ground from the water pipe to an exterior ground rod. Does anyone have advise or suggestions on swapping out the pipe.
My biggest concern is attaching the PVC to the Brass shut off valve i just installed.
Any help wout be great.
McSweny1103 is offline   Reply With Quote
Old 06-14-2010, 01:42 PM   #2
Long-Time DIYer
Mike Swearingen's Avatar
PVC is for cold water only and drains. If you're going to replace all of that old galvanized, I would consider either CPVC or PEX, both of which allow hot water lines.
Why can't you just ground your water heater (with an insulated ground wire) back to your panel ground buss?
Mike
Mike Swearingen is offline   Reply With Quote
Old 06-14-2010, 02:38 PM   #3
Then how is the ground buss grounded, if it is not grounded through the cold water line?
Old 06-14-2010, 04:00 PM   #4
Long-Time DIYer
The panel should be grounded to a long ground rod in the ground. My water heater has 10/2 w/ground wiring from a 30 amp panel breaker and has always been grounded back through the panel only (since 1977).
Mike
The Following User Says Thank You to Mike Swearingen For This Useful Post:
McSweny1103 (06-15-2010)
Old 06-14-2010, 04:44 PM   #5
Mike
Is your water heater gas or electric?
Old 06-15-2010, 06:22 AM   #6
Rewards Points: 1,216
Mike I think your on the wrong track here it sounded like he was talking about the main panel ground not a hot water heater ground... I didn't see hot water heater in his post but my eyes are starting to go.
COLDIRON is offline   Reply With Quote
The Following User Says Thank You to COLDIRON For This Useful Post:
Old 06-15-2010, 09:25 AM   #7
Thanks for the help guys, between here and my electrical forum post I have figured out my answers. I will use the CPVC for the new water lines, and I will run a #6 insulated wire from the box to the copper service.
Old 06-15-2010, 09:31 AM   #8
Long-Time DIYer
You are right, COLDIRON.
WHERE did I get water heater? My MIND is starting to go. LOL
Rotten bathroom subfloor tallycat77 Flooring 14 02-08-2013 09:59 AM
replace galvanized pipe below kitchen sink? Jeremy Hillary Boob, PhD Plumbing 3 04-03-2009 08:39 AM
firring out concrete wall for electric and insulation trouble Building & Construction 9 02-04-2009 11:40 AM
Old Galvanized shower/bath inlets Relpace Pex? sssalas Plumbing 2 09-08-2008 03:56 PM
Darn. A leak in my main supply from street, Galvanized. In foundation under slab? twilightcall Plumbing 2 07-31-2008 12:22 AM
