Rotten Eggs With Only Hot Water - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-15-2013, 05:35 PM   #1
Rotten eggs with only hot water
We moved into our home (built in '95) about 4 months ago and only in the past few weeks we have started smelling rotten eggs from all faucets and only with hot water. I did some research and I see people are saying to replace the anode rod, that the water is reacting with the anode rod and causing that smell.
My main problem with that is this anode rod's bolt head is very shallow, trying to pull as hard as I need too while trying to keep the socket on the bolt just is not working. If I don't hold the bar down, I just turn off the bolt. I've tried using some PB Blaster in hopes that it might loosen it up a bit but it has done nothing.
My boss called a plumbing buddy of his who is very familiar with the issue and told me replacing the rod is a temporary fix and that there is an issue with the water that is causing it. We do have well water but it was shocked and clear of bacteria when we closed on the house.
1) Should I be looking to use some type of electric impact wrench on the bolt? I do not have a compressor yet.
2) If the water is the culprit, would shocking the well and flushing the water heater fix the problem or has the damage already been done?
ckratz is offline   Reply With Quote
Old 10-15-2013, 05:53 PM   #2
bbo
i've used an impact wrench on my bolt as without it, I was just turning the water heater. Some plumbers discount the anode rod. I'd say replacing it is a lot cheaper.
bbo is offline   Reply With Quote
Old 10-15-2013, 06:05 PM   #3
Rewards Points: 282
Impact wrench is best, if not, then 3/4inch drive socket with breaker bar - you need leverage. Shut water off to hwh, and drain out about 6 or 7 gallons of water before you start. Have someone hold onto tank. Replace anode rod with zinc rod not aluminum or magnesium. Even this is no garantee it will stop the smell, but could help.
Bacteria is the main cause. The well water is probably the culprit and will need to be addressed at some point. This is an interesting read if you have some time. (see link)
How old is the hot water heater? When was the last time it was flushed and cleaned. It may be too late, the damage may already be done. If you can, post a pic of the old anode rod you took out. Thanks.
solving rotten egg smell
jmon is offline   Reply With Quote
Old 10-15-2013, 06:10 PM   #4
Rewards Points: 13,712
http://www.cleanwaterstore.com/techn...ater-odors.php
jmon (10-15-2013)
Old 10-15-2013, 08:10 PM   #5
I'm not sure how old the water heater is, it may be well over 10 years old, I'll have to find out. I just flushed it last weekend but just flushed it, did not use anything to clean it (like the solution in the link posted above). I think I'm going to try to attack all 3 things: shock the well, try to replace the anode rod, and do the peroxide cleaning solution in the heater. Even though it is supposedly harmless, we can't stand it. If I manage to get the anode rod out, I will post a pic. Thanks guys.
The Following User Says Thank You to ckratz For This Useful Post:
jmon (10-15-2013)
Old 10-15-2013, 08:17 PM   #6
Rewards Points: 282
I don't blame ya. Addressing all three issues at once is a good strategy, hope everything works out for you and no more smelly water. Let us know how everything works out or if you need anymore advice. Thanks.
Old 10-15-2013, 08:28 PM   #7
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Id check the local box stores to see if they have any hot deals on water heaters myself.
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
The Following User Says Thank You to plummen For This Useful Post:
jmon (10-15-2013)
Old 10-15-2013, 09:48 PM   #8
Rewards Points: 282
ckratz, Plummen makes a great point. It's always good to have a back-up plan just in case everything falls apart on you. Being hwh is well over 10 years old, the damage may already be done and you may not even be able to get the anode rod out. Even if you do, you may risk breaking off the hex nut, etc. Of course you won't know until your try. Just a thought.
Old 10-15-2013, 10:26 PM   #9
Plumber
TheEplumber's Avatar
Rewards Points: 676
ckratz, Plummen makes a great point. It's always good to have a back-up plan just in case everything falls apart on you. Being hwh is over 10 years old, the damage may already be done and you may not even be able to get the anode rod out. Even if you do, you may risk breaking off the hex nut, etc. Of course you won't know until your try. Just a thought.
Do you have the head room to install a new rod?
The Following User Says Thank You to TheEplumber For This Useful Post:
jmon (10-16-2013)
Old 10-16-2013, 10:37 AM   #10
Rewards Points: 282
Very true. Good catch "E". He may have to cut the old one as he's taking it out, if there's anything left to it. Which for obvious reasons should be done very carefully. They do make new ones which are collaspsable for this purpose. However, with the hwh well over 10 years old, it may be too late.
Old 10-16-2013, 02:55 PM   #11
Rewards Points: 1,952
http://www.sdstate.edu/abe/wri/water...-Questions.pdf
Read this and decide what works for you.
Can I turn off hot water to Washing Machine? okk Plumbing 12 08-10-2012 07:14 PM
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 11:19 AM
Cold water is warm - hot water leak under slab? Homerepairguy Plumbing 9 10-13-2010 08:17 PM
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 08:42 AM
How Do I Properly Shock Chlorinate a Water Softner classicflytyer Plumbing 5 07-14-2009 12:15 AM
