Rotten Egg Smell From Toilet - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-08-2011, 05:16 AM   #1
Rotten Egg smell from toilet
I had my bathroom fully remodeled over a year ago. And recently I have been smelling a rotten egg smell coming from around my toilet, I dont have any leaks and the smell is only from my toilet. Was my drain not properly installed?? My toilet is not clogged . Can someone HELP???!!!!!
djbthunder is offline   Reply With Quote
Old 12-08-2011, 05:51 AM   #2
Lightfoot's Avatar
Rewards Points: 272
it could be the wax ring. if it's bad, it doesn't necessarily have to leak water, it could be just letting sewer fumes in. that would be the first thing i would check. they only cost like 3 bucks.
Lightfoot is offline   Reply With Quote
Old 12-08-2011, 06:03 AM   #3
Rewards Points: 582
do you have ceramic tile on floor....if you do they may have not raised flange and as mentioned bowl wax may not be sealing leaving in alittle sewer gas...
Old 12-08-2011, 06:12 AM   #4
Rewards Points: 13,960
When setting a toilet it's hard to get the wax ring to completly seat in one shot. When I'm installing it I set the toilet and rock it from front to back while pressing down, tighten the nuts on the bolts until there snug, use the toilet for a day then go back and finish tightning the nuts.
If you try and use the nuts to pull it down tight to the floor in one shot you may break the flange or crack the toilet.
Old 12-08-2011, 09:11 AM   #5
Doing it myself
Alan's Avatar
Rewards Points: 2,086
I honestly cannot agree with anything above ^^^^^
Sewer gas does not generally smell like rotten eggs. Rotten egg smell is usually sulfur in the water. Are you on a well water system?
Journeyman Plumber
The Following 2 Users Say Thank You to Alan For This Useful Post:
oh'mike (12-08-2011), VIPlumber (12-08-2011)
Old 12-08-2011, 05:04 PM   #6
Rewards Points: 175
also calk around toilet with kitchen/bath calk.
Old 12-09-2011, 10:30 AM   #7
I have ceramic tile and i will try a new wax ring later tonight also. I dont have well water. And the smell is only around the toilet. Thanks everyone for your help, I will let the forum know how it goes
Old 12-09-2011, 08:36 PM   #8
Rewards Points: 582
when you lift commode see how far flange is below finished floor....
Old 12-09-2011, 08:47 PM   #9
Experienced
Jackofall1's Avatar
I always recommend to not do exactly this, the reason is if there is a leak you will do far more damage before its noticed.
Mark
The Following User Says Thank You to Jackofall1 For This Useful Post:
Bud Cline (12-09-2011)
Old 12-09-2011, 10:26 PM   #10
Tileguy
Bud Cline's Avatar
Rewards Points: 558
NEVER caulk completeky around a toilet foot.
Old 12-10-2011, 10:11 AM   #11
Doing it myself
Alan's Avatar
A lot of people don't like caulking them. I have 2 in my house that aren't caulked because they were leaking and I had to re-set them. I will caulk them soon, and i will probably leave a small gap in the back where it's unable to be seen.
BUT on the flip side. Plumbing code requires that the connection between the toilet and the floor be made water tight. They have to be caulked. There really are no if's and's or but's about it when we're building a new house.
The other thing that I find caulking does, especially on tile floors, is to help support the bowl.
Journeyman Plumber
Bad smell in crawl space. John_W General DIY Discussions 34 06-03-2014 12:57 PM
Rotten egg smell from bio-clean, safe? Johndc Plumbing 0 02-22-2011 09:46 PM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 07:52 PM
Rotten toilet flange and sunken slab mcmarsha67 Plumbing 1 01-17-2009 01:41 PM
Toilet jpark Plumbing 18 01-05-2009 07:12 AM
