Rotten Egg Odor In Hot Water Only - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-31-2011, 09:58 AM   #1
Rewards Points: 65
Rotten egg odor in hot water only
Have rotten egg odor in hot water only. Have 85 ft well w/electric water heater. Have been adding Clorox every other day: works fairly well, but is a PIA in winter (-20 deg not unusual here). Any other relativly economical suggestions w/be greatly appreciated. Have already had several expert estimates in $3-5K solutions. Getting city water piped in in less than 2 yrs. Any suggestions for addinng Clorox from inside of home? Have already changed anode rod.
rpulley825 is offline   Reply With Quote
Old 10-31-2011, 10:15 AM   #2
biggles's Avatar
put the HWH gas valve into pilot and shut the cold feed and drain it down the open the feed,and let it flushout the bottom hose connected into the yard even if your up into the yard out of a basement...fill it for 5 minutes shut the water let it drain and do it 2 or 3 times.....might be crap at the bottom of the tank tainted the water....but definitly set that gas valve to pilot... or the cold water will call it on...get back should do it
Old 10-31-2011, 10:21 AM   #3
Tileguy
Bud Cline's Avatar
Rewards Points: 558
This one is easy. Just replace the gizmo in the water heater. Can't think of the name of it right now but there is a rod threaded into the top of electric hot water heaters that collects impurities over time. At some point that rod will have done all it can do and needs to be replaced.
It just came to me. I think it is called an "anode rod" and it is there to be sacrificial. The stink is worse in systems that use well water.
End of problem.
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 11:19 AM
Need help figuring out walk-out basement water intrusion issue toomanypets General DIY Discussions 18 08-29-2011 08:34 PM
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 08:42 AM
How Do I Properly Shock Chlorinate a Water Softner classicflytyer Plumbing 5 07-14-2009 12:15 AM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 09:31 PM
