-   -   root killer dangerous to pipes? (http://www.diychatroom.com/f7/root-killer-dangerous-pipes-21440/)
darsunt 05-25-2008 07:57 PM
I have a slow shower drain that is supposed to have root problems. I've also been told root killer chemical can damage pipes.
I've looked at a root killer brand at Osh and there is no mention on the package of danger to pipes. If it can hurt pipes, what precautions should I take?
darsunt 05-25-2008 11:55 PM
I understand that copper sulfate is the one that can hurt pipes, and may also be illegal in some areas.
I've read favorable reports on dichlobrnic. Is it as good as they say? It's supposed to be safe for pipes and safe for the environment. One brands I've read about is Rootx
Ron The Plumber 05-26-2008 09:36 AM
Why does your shower drain have roots in it? How do yoiu know for sure it does?
Roots are mainly found in mainline.
majakdragon 05-26-2008 10:00 AM
I agree with Ron. What you probably have is hair and soap residue. Best bet is to snake the line out. If you feel you must use a chemical, use an enzyme drain cleaner such as Draincare by Zep. Enzyme cleaners cling to and eat organic clogs. Caustic chemicals merely eat a small hole and run down to the mainline, leaving most of the clog there to start over.
darsunt 05-26-2008 01:37 PM
Our handyman ran a power snake down there a couple of times, and then told us it was roots. I suppose it is possible because I just replaced a toilet in that house, and all around the flange was a nasty ring of roots and dirt.
majakdragon 05-26-2008 03:08 PM
Wow, that is strange. You need to realize that if roots have grown inside of the pipe, there are now holes in the pipe that will not "heal". They will only get bigger and possibly collapse eventually. Time to start planning a major repiping job.
darsunt 05-26-2008 07:44 PM
I've heard that the roots around the toilet flange happens a lot, I was just hoping that it would never happen to me.
The kitchen sink, lavatory, ect run fine, so assuming our handyman is correct, there is some kind of root invasion in the shower drain before it reaches the main line.
I would then need (for a short term fix) to put the root killer in the shower/tub. But now I've read that even dichobrnic shouldn't be used from the bathtub. Will it damage the pipes? What is a person to do? (Sigh)
