-   -   Rookie question- sink drain (http://www.diychatroom.com/f7/rookie-question-sink-drain-35606/)
DSKUP 01-10-2009 08:11 PM
I'm remodeling a bathroom and plan to move the sink to an adjacent wall. Is it acceptable to run supply and drain lines (with appropriate slope) through the wall corner, or do I have to go under the floor? I'm reluctant to run through the joists because I will be adding a bath tub that wasn't there earlier.
Bob Mariani 01-10-2009 08:21 PM
yes you can do this
majakdragon 01-11-2009 09:30 AM
Yes, it is permissable, but do not forget about the vent line on the sink piping. It also needs to be re-run.
DSKUP 01-11-2009 09:35 AM
Thanks. It's a very short run, so I'm assuming I can wet vent the sink (<3 ft.).
Bob Mariani 01-11-2009 09:37 AM
wet venting is not permitted by code in most areas. Maybe in the south where everything is okay.
ponch37300 01-11-2009 06:20 PM
I'm just asking out of couriousity but don't you get so many feet from the sink to the vent? Thanks
Nestor_Kelebay 01-11-2009 06:39 PM
Bob & Majakdragon:
I don't see a problem running supply piping around a corner with 90 degree angles, but where I live, you cannot have a 90 degree angle on a drain line because of the resulting difficulty in getting a snake to go around that corner (and to pull the snake out of the piping again). You can have two 45's to make a corner, and that's what's commonly done to turn to vertical. However, this guy wants to embed the 90 in the wall, and so two 45's wouldn't work there.
Unless I'm misunderstanding and the "no 90's" rule only applies to larger diameter drain piping.
DSKUP: I'd check with your local plumbing inspector on this. You don't want to do a bunch of work and then end up having to redo it all.
