Rookie DIY Question - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-14-2009, 03:57 PM   #1
Rookie DIY Question
Basement coming on great but now a bathroom question.
In connecting the copper pipe to shut off valve is there another way to connect besides sweating?
will_53115 is offline   Reply With Quote
Old 01-14-2009, 04:45 PM   #2
yes, depends what type shut-off valve you get, you can go with a compression fitting, no soldering
LIVING THE DREAM
DUDE! is offline   Reply With Quote
Old 01-14-2009, 04:46 PM   #3
Rewards Points: 2,906
There are different kinds of ways to connect copper piping to a valve, but I expect 99% of the people in here would agree that soldering is the most reliable method.
Threaded connections can be troublesome in getting the valve body at a desireable angle.
Compression fittings require that a brass ferrule be crimped onto the copper pipe, and so switching to a different kind of connection requires cutting the pipe a bit shorter to eliminate the brass ferrule from the pipe.
Soldering is the best way to connect the valve in my books.
And the best shut off valve to use is a ball valve. As long as the valve is in the open position when it's soldered in, the teflon seals in it will stand the heat.
Bashing my head against the walls in some of the internet's finest chat rooms.
Nestor_Kelebay is offline   Reply With Quote
Old 01-14-2009, 05:46 PM   #4
bradnailer's Avatar
If you do decide to sweat a valve on, I'd strongly suggest you sweat on a male threaded adapter then use a female threaded valve. Shut off valves don't last long where I live so with the threaded adapter, I don't have to sweat a new valve, I just unscrew the old one and screw on a new one.
bradnailer is offline   Reply With Quote
Old 01-15-2009, 11:16 AM   #5
You can purchase compression shut-off valves in either straight or angled configurations. Use two wrenches when installing so the valve does not turn and the nut is properly tightened. Make sure you push the valve all the way onto the pipe before tightening.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
hrv question indep HVAC 3 07-17-2008 11:39 PM
Basement vapor barrier question rob7young Remodeling 2 04-13-2008 10:10 AM
New service Question Onytay Electrical 1 10-24-2007 06:47 AM
One furnace question and one thermostat question lh0628 HVAC 4 10-11-2007 11:17 PM
