Rooftop Gas Pip - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-01-2013, 09:35 PM   #1
rooftop gas pip
The contractor I worked with, ran the gas pip up the side of the house onto the rooftop, it makes an L shape then into the roof again. I does not look very nice for a residence and I would like to move it so that it's not so exposed. How can I move it without it being so costly?
rox03 is offline   Reply With Quote
Old 04-01-2013, 10:00 PM   #2
Roofmaster
Rewards Points: 2,210
1. " Pip " Is a character in a Dickens Novel.
2. What is "So Costly"
3. Without any idea regarding how your home is built, it is absolutely impossible to offer any advice except the following:
Gas is explosive. It is not prudent to even consider working with gas pipe without experience, or the correct tools. If you do not own several high quality pipe wrenches, or do not know what NPT, union, coupling, street L or drip leg means forget it, and hire a pro. If you screw up plumbing, you have a leak. If you screw up gas, you have an explosion. Usually a Big Explosion.
A word to the wise.
The Following User Says Thank You to jagans For This Useful Post:
fetzer85 (04-01-2013)
Old 04-01-2013, 11:31 PM   #3
Always learning...
fetzer85's Avatar
Rewards Points: 262
Are you saying the contractor you hired ran the gas pipe? If so, any reason this wasn't brought up beforehand?
fetzer85 is offline   Reply With Quote
Rooftop unit Trane XL14C compressor vibration joeyl HVAC 24 12-13-2014 03:02 AM
3/4 indoor motor kit (ICP rooftop A/C) marcoaa HVAC 4 05-15-2012 06:13 AM
Building rooftop deck dwt Building & Construction 4 07-22-2011 03:51 PM
Rooftop Deck Question EZe Building & Construction 0 08-03-2010 09:04 PM
Trane Rooftop Unit junior40 HVAC 1 11-03-2008 04:22 PM
