Roof Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-27-2013, 06:21 PM   #1
Roof pipe
I need to replace my roof pipe that hooks up to my sink n shower. Where do I buy a new one. Mine is metal I think. Someone told me I could u PVC pipe instead. But I don't want a white pipe sticking out of my roof. I'm guessing mine is around 18 in or so from what I see. Also do they make the square ones that sit close to roof so it looks neater
ecocco1469 is offline   Reply With Quote
Old 07-27-2013, 06:40 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 562
sounds like you're describing a roof vent?
your material choices from cheaper to most expensive are-
PVC or ABS, galv. sch. 40 steel, cast iron.
All your choices are round pipe and need to extend at least 6" above the roof- more for cold climates so they do not get blocked by snow.
I assume you will make your repairs in the wall below the roof- the proper way.
Also, replace the roof flashing while you're at it
Old 07-27-2013, 08:50 PM   #3
Plumber_Michael's Avatar
By square ones, are you talking about the vent cap, the flashing, or the pipe itself? That last one would be humorous...
If its a cap you're asking about, that type of ventilation doesn't require any.
A cantex would be the easiest way to tie back into the existing nipple or tee for a DIY plumber
Plumber_Michael is offline   Reply With Quote
Old 07-28-2013, 08:18 AM   #4
Lightfoot's Avatar
Rewards Points: 272
scuff it up, then prime and paint it whatever color you like. still your cheapest and easiest route. You certainly wouldn't be the only one with a white roof pipe, they are everywhere.
Flashlight: A cylindrical container used to store dead batteries
Lightfoot is offline   Reply With Quote
Old 07-28-2013, 08:51 AM   #5
Rewards Points: 13,450
If you use ABS pipe it will be black and no show as much.
No it can not be square and should not be capped.
Air needs to pass over it to create a venturi to suck out the sewer gasses.
Old 07-28-2013, 09:05 AM   #6
747
registered
747's Avatar
Rewards Points: 534
geez all you do is paint to match your roof. Most shingle manufacturers have cans of spray paint to match there shingles. Pvc is the way to go.
747 is offline   Reply With Quote
A couple furnace gas pipe questions, and an entire plan to replace my gas valve richapple HVAC 13 12-05-2012 11:33 AM
Proper transition between shed roof and shingled roof? aribert Roofing/Siding 9 04-12-2012 03:17 PM
$2000 for a few pipe stands for roof??? noquacks Roofing/Siding 7 03-21-2012 09:08 PM
2" pipe on above sink in wall rusted out in a spot bryanp22 Plumbing 9 02-23-2012 08:29 PM
Soil waste pipe through pitched roof DIYifposs Roofing/Siding 1 11-21-2009 02:34 AM
