Roman Tub Spout Replacement - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-18-2009, 03:36 PM   #1
Question
Roman Tub spout replacement
HELP!!!!!I have a roman tub that was put in when the house was built about 10 or 12 years ago. The access door is in my laundry room (the other side of the back wall of the tub) and the faucets and spouts do not come out of the wall. They are on the far right corner of the tub and therefore cannot be reached by going through the access door. The spout is apparently connected underneath. I have had 4 plumbers out and they are not even sure if they can access it by cutting a whole in the wall. Therefore they can't even give me an estimate on what it might cost or if it can be done at all. Does anyone have any suggestions?
hunter3263 is offline   Reply With Quote
Old 09-18-2009, 07:51 PM   #2
how about a couple pictures.
plumber Jim is offline   Reply With Quote
Old 09-22-2009, 09:10 AM   #3
Barry
If I'm not mistaken, you'll need to remove the front panel of the tub for access. Typically it involves removing the caulk/sealer around the edges of the panel, then using suction cups (or a plunger) to pull the panel forward. You have to be very careful not to break the panel.
Barry
Tub Refinisher is offline   Reply With Quote
Old 09-22-2009, 04:45 PM   #4
Thanks Barry.....I'll give it a try
Bathtub Spout Replacement cspirit Plumbing 4 03-18-2011 06:39 PM
Bathroom Tub Diverter Spout karenmc Plumbing 3 07-24-2009 03:23 PM
Frustrating bath spout removal problem martinvancouver Plumbing 6 07-09-2009 12:38 PM
Tub Spout Help showerhelp Plumbing 9 11-13-2008 07:15 PM
Bathtub Spout Leaks Behind Spout (pics) wallix Plumbing 7 10-14-2008 03:41 PM
