Old 01-17-2009, 12:40 PM   #1
Question Roman tub faucet kit
I have the same situation as Tarheel: how to remove and replace a faucet kit on a Roman tub, with no access to the area underneath the tub deck. Assuming I can remove the old faucet and handles by undoing the set screws, how do I know what brand the valves are? Does it matter? In other words, could I replace an old Delta kit with a Moen kit?
sortofhandy is offline   Reply With Quote
More On This Topic
Hi this is Jon on behalf of Expert Village in this video clip we'll be removing our insert. Our next step is to remove this insert here, this is what houses the o-ring that helps make that seal nice and tight. So if my initial assessment is correct once... Read More »
Hi this is Jon on behalf of Expert Village in this video clip I will show you how to remove your side trim boards. On this side we need to remove our gutter first before we can have access to our trim board. You need to unscrew where you gutter... Read More »
It's easy for a bathroom to begin looking dated over the months or years. It is a room built for utility that people often do not think much about and do not want to dedicate a lot of financial resources to, but there are ways of giving your bathroom a... Read More »
Anyone with a disability wants to feel as though they have full access to their home. In reality, most homes aren't designed for a wheelchair or even a walker. Fortunately, there are several steps you can take to modify your home to improve your... Read More »
Faucets should accentuate the overall appearance of your bathroom. You can choose from a large selection available at hardware stores, home centers, bath remodeling showrooms and plumbing wholesalers. You can also shop online. Whether you are replacing... Read More »
No hot water pressure at kitchen faucet tracker883 Plumbing 2 12-30-2008 07:10 AM
Roman Tub Faucet Removal LennyM Plumbing 3 08-02-2008 03:22 PM
how to remove roman bath faucet? tarheelblue Plumbing 1 06-07-2008 08:38 PM
Faucet Drain Lever Installation DK75 Plumbing 3 05-21-2008 12:08 PM
Replacing Faucet for a Roman tub phibui Plumbing 8 02-14-2008 08:28 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
