-   -   roman tap??? help (http://www.diychatroom.com/f7/roman-tap-help-20894/)
TEEBOW 05-11-2008 05:22 PM
roman tap??? help
im installing a air tub with roman taps and need to know how far over the main spout should over hang the tub?
the taps will not be install on the tub but in the deck/tile base of the tub
and how to measure it?
Boston Plumber 05-11-2008 07:52 PM
Hey Teebow:
You raise good question because deck mounted roman tub valves can cause troubles for people installing these IF they did not plan on DEPTH involved.
In this case, I would just place the spout approximately where you think it should go...meaning you will just hold it in place over the place you intend to install....then you need to evaluate this. There is no set standard!! Just make sure you leave enough room around that tub spout that you can secure and connect it from underneath as needed WITHOUT the nuts/washers running into the tub itself!!!
You want to maximize fill while not intruding on space/comfort of person(s) using tub....this can be tricky!!
I have even had a few customers that simply purchased the wrong valve for the job...needed higher arch and deeper roman tub spout...and so had to return or I had to install at the tub itself (drill holes in tub top).
Are you setting this tub in a bed of mortar or similar...? The instructions will recommend this and so do I. Read up....
Let me know if need more. Good luck.
