Old 01-16-2009, 01:27 PM   #1
Default rocking chair or toliet?
I have a huge problem with my toliet. I've replaced the wax ring and screwed it back down. It was fine. Then one day I sat to do my business, and bam I'm rocking. and not just a small rocking i mean one where i thought the toliet was tipping over. Not so cool when your doing your business!!!! so I went to screw the toliet back down, seeing how that what seemed to be the problem , and of course it wasn't. Not really sure whats wrong with it. It's screwed in properly. Any suggestions to my rocking toliet problems!?
kahnegirl is offline   Reply With Quote
Old 01-16-2009, 01:33 PM   #2
BDN
Remove toilet and check the flange. See if it's broken, cracked, or the bolts striped out of the holes.
johnnydanger is offline   Reply With Quote
Old 01-16-2009, 04:32 PM   #3
Whats it look like.
Old 01-16-2009, 05:26 PM   #4
011000100110111101101111
DangerMouse's Avatar
the flange is what the toilet is mounted to. sounds like it may be broken to me.
DM
Magical, Musical, Mysterious FUN!
http://www.youtube.com/user/MickeySoume
Now Featuring: Mickey's Multi-Talented Mutts!
Old 01-16-2009, 06:19 PM   #5
What is the best way to replace a flange if it is broken? They are glued to the drain pipe right?
ponch37300 is offline   Reply With Quote
Old 01-16-2009, 09:38 PM   #6
BDN
Some are made of PVC and some are Cast iron. The repair really depends on how it's broken. If the outside of the flange is broken where the bolts are at, you can get a flange repair kit, which is basically a piece that goes around the flange with new bolt holes. If it's completely busted then you can use a "tighten to fit" setup.
I've not had any experience with either product, but I did a little research on it before.
Old 01-17-2009, 01:29 AM   #7
Just make sure the flange really is broken. You don't want to replace that if you don't have too, especially if it is iron.
darsunt is offline   Reply With Quote
More On This Topic
Body Wax Demonstration
Body Wax Demonstration by Expert Village
On behalf of expertvillage.com, my name is Angie Yarid from LA Wax and Skincare Center in Miami, Florida and today we’re talking about body waxing. Okay let’s look at a little demonstration of what waxing does to the skin and how we apply it... Read More »
Some tips for my clients is if you normally have a problem with getting red after waxing, take an antacid about thirty minutes before you go get your waxing done. This helps to keep the skin from getting as red as it normally would, and just helps with... Read More »
Learn How to create rocks in a pond for encaustic wax painting in the free art lesson from our encaustics and art technique expert. Read More »
Wakeboard towers add value and style to your boat. Not only are they practical for holding wakeboards, but they are also great for mounting speakers and other accessories. Besides figuring out how to build it yourself, there are several options available... Read More »
Today we’re replacing the toilet. We’re just about to install the new toilet. It’s been pre-assembled a while ago. What you want to do in here is get all this old caulking off the floor because you’re going to have to re-caulk it... Read More »
DIY Chair mat from plywood and carpet tiles jbwaechter Flooring 3 08-20-2009 08:29 AM
Installing Chair Rail up staircase? tomrash Carpentry 2 01-12-2009 03:04 AM
decorative trim and chair rail. What are the rules to make it look good? Bacardi 151 Carpentry 10 10-18-2007 03:37 PM
Painting Chair for Nursery cibula11 Painting 11 06-08-2007 10:39 PM
Wall lamps and chair rail alvanos Carpentry 1 04-26-2006 01:35 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
