RO / Backflow Preventer - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-17-2013, 04:04 PM   #1
m.h
RO / Backflow preventer
So we are selling a home next week and the buyers inspector is requesting us to "Install a backflow prevention valve in the RO system". I cant find any info online about where said product can be purchased or if I find it, where within the network of tubing I would install the thing??
Any ideas?
m.h is offline   Reply With Quote
Old 09-17-2013, 04:14 PM   #2
Water Treatment
Rewards Points: 900
Ask if a spring check valve between the ro and the main house line would work?
There are plastic spring check valves that can be had that are 3/8 or 1/4 in and out.
Also ask as to Why there should be one as every ro system that I have seen does not have one, and that is from the cheep box store to the more costly ones.
Akpsdvan is offline   Reply With Quote
Old 09-17-2013, 06:49 PM   #3
Rewards Points: 2,036
Why? Ask for a specific code section.
Old 09-17-2013, 06:53 PM   #4
dannyoung85's Avatar
The company I work for does quite a bit of commercial plumbing and when we are required to hook up an appliance like a R.O. System or a hard piped coffee brewer we are required to put in a back flow preventer between the branch line feeding the appliance and the appliance itself. We typically use like a Watts Model #909 or #919. Some of the back flow preventers (mainly a RPZ type) will require an air gap and route to a drain. So keep that in mind before making your purchase. I do not know if the big box stores carry these, but I'm sure your local plumbing supply house will.
dannyoung85 is offline   Reply With Quote
Old 09-17-2013, 07:05 PM   #5
m.h
It does have a line going to the main drain of the sink. So just put a check valve in the feed line and call it a day?
Old 09-17-2013, 07:17 PM   #6
Yeah I would see if they think a check valve would be enough. A backflow preventer is a little more complicated of a device; it has a couple of isolation valves, a couple of check valves and some test ports. In your situation I would think that a spring check valve would be good enough.
Old 09-17-2013, 07:25 PM   #7
Plumber
TheEplumber's Avatar
Rewards Points: 802
Disconnect it and sell the house......
I've been looking through my UPC book- if RO is considered a pure water treatment system and you're governed by the UPC then it needs protection like dannyoung suggested. That's my interpretation
Old 09-17-2013, 08:53 PM   #8
Master Plumber
Javiles's Avatar
Rewards Points: 996
touchy subject technically it falls under cross contamination no direct contact with the drain receptacle from a dispenser on a domestic water system. so it needs to be ???? what,, come on plumbers lets all say it together
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 09-17-2013, 10:27 PM   #9
Water Treatment
Rewards Points: 900
How did the human race ever get to the year 2013 with out the help of GOVERNMENT REGS to make sure that we are safe?
The Following User Says Thank You to Akpsdvan For This Useful Post:
TheEplumber (09-17-2013)
Old 09-18-2013, 06:24 PM   #10
Install an ASSE 1022 backflow on the RO drain line. That will make you happy...
Backflow preventer on water heater in well-water system pnschi Plumbing 4 09-10-2012 08:59 AM
Backflow preventer adapters keeps spitting water htabbas Plumbing 1 06-14-2012 04:52 PM
Backflow Preventer or Lift Station? roztom Plumbing 21 01-29-2012 07:03 PM
quick question about backflow preventer mynd66 HVAC 8 11-07-2009 07:03 PM
Backflow Preventer - M2 or M3? velcrobots HVAC 6 10-04-2009 12:20 PM
