Old 01-11-2013, 09:55 PM   #1
Riser pipe needed
We have a clawfoot tub that has a handheld shower with hose attachment. the hose runs up our wall and is held on the wall with a mount. I am trying to find a distributor that sells just the riser pipe with the same threads as the handheld hose so I can make a better looking shower. Plus the riser pipe would have a bend that would place a shower head more directly over the center of the tub.
Any ideas where to find the riser pipe? I have looked on line but find the same junk from site to site.
Thank you
Tom
roxytom is offline   Reply With Quote
Old 01-11-2013, 10:22 PM   #2
Riser pipe needed
try this site
http://www.signaturehardware.com/class209
be careful my advice only comes from general knowledge i know about the 4 rules it takes to plumb and they are
1 poop needs to flow down hill. 2 hot on left cold on right
3 i get a pay check on Mondays 4 do not chew finger nails at or after work.
jaydevries is offline   Reply With Quote
Old 01-11-2013, 10:24 PM   #3
Roofmaster
Riser pipe needed
Ok so Who is the Manufacturer of the junk you have now, about what year was it installed, and where do you live?
Also there are probably 500 or so different models of this type of thing so a picture or two would be helpful.
" A lot of men build things, and a lot of things fall down "
Old 01-12-2013, 05:35 AM   #4
Riser pipe needed
Here is photo of the faucet set... Note that the shower hose rest is detachable. See the nut below the rest. The riser pipe could attach there. I'll have to take it off after wirk today to make sure of style thread, but I believe it is pipe...
Old 01-12-2013, 07:26 AM   #5
Super Moderator
Riser pipe needed
That is a compression fitting with a rubber washer----you will be well served by identifying the faucet manufacturer----
Old 01-12-2013, 09:51 AM   #6
Riser pipe needed
-you will be well served by identifying the faucet manufacturer...
Yeah Mike, I am gonna check that out tomorrow hopefully.. Too much real work today... Tomorrow I will work at home.... Oh wait, that is real work also... Just don't get paid for it
Need advice on rusted pipe problem silencer Plumbing 16 12-02-2012 09:59 AM
Joining 1/4" walled poly pipe IDEAS NEEDED!! CallMeChaz Plumbing 0 05-22-2012 10:04 AM
Question about copper pipe agroom Plumbing 3 10-27-2011 03:18 PM
Condensation in Gas Furnace Vent Pipe chanco HVAC 2 01-08-2011 05:01 PM
Flange Help Needed tajones44 Plumbing 2 07-11-2005 05:42 PM
