Riser Clamp Size - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-22-2014, 08:38 PM   #1
Rewards Points: 282
Riser clamp size
I need a riser clamp to hold a section of my cast iron stack while I cut it. The outer dimension of the stack is 5" so I asked for a 5" riser clamp. But it seems to big. I expected it to wrap pretty close around the pipe but it doesn't. Did I ask for the wrong size?
dgfit is offline   Reply With Quote
Old 01-22-2014, 08:47 PM   #2
Rewards Points: 14,306
Sure it's not a 4" pipe?
http://www.engineeringtoolbox.com/ca...ns-d_1751.html
plummen (01-22-2014)
Old 01-22-2014, 09:17 PM   #3
Rewards Points: 282
I'll check the measurements. Thanks.
Old 01-22-2014, 09:39 PM   #4
If this is a residential house you have 4" cast not 5".
jmon (01-22-2014)
Old 01-22-2014, 11:29 PM   #5
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Ive never even seen 5" pipe .
3-4-6-8-10.........
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 01-22-2014, 11:36 PM   #6
Plumber
TheEplumber's Avatar
Rewards Points: 904
3-4-6-8-10.........
Its rare but it does exist, seen it twice in 25 years.
OP- get a clamp for 4" CI. Lengthen the bolts if needed
The Following 2 Users Say Thank You to TheEplumber For This Useful Post:
plummen (01-22-2014), tonysteve66 (01-23-2014)
Old 01-23-2014, 05:24 AM   #7
Agree with TheEplumber..
We not have much uses of drain iron stack. but if size is your're sayin..5"
the best option in a 4" riser clamp ..
A normal riser clamp have 2" screw.. so it is good with that
tonysteve66 is offline   Reply With Quote
Old 01-23-2014, 08:33 AM   #8
Rewards Points: 282
Yeah I remeasured and I don't know how I convinced myself it was 5 inches. Going back to get a 4 inch clamp.
Old 01-23-2014, 12:00 PM   #9
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,728
Ayuh,.... There's yer Problem,.....
Pipe is sized by it's Inside Id,...
The Following User Says Thank You to Bondo For This Useful Post:
plummen (01-23-2014)
Old 01-23-2014, 07:28 PM   #10
Rewards Points: 282
The 4" clamps fit great
The Following 2 Users Say Thank You to dgfit For This Useful Post:
plummen (01-23-2014), TheEplumber (01-23-2014)
Proper trunk/duct size? gjones HVAC 7 12-06-2011 07:18 PM
Concrete steps with one side against wall oxicottin Building & Construction 12 10-14-2011 02:12 PM
Rule of Thumb for Trowel size and Spacer size please.. K.M.G Flooring 7 02-08-2010 08:13 PM
Determining Boot/Register Size Earnie HVAC 15 12-31-2009 05:00 PM
Building a patio cover...span and size of lumber Q's jongordo8 Building & Construction 1 08-30-2009 12:08 AM
