-   -   Riser clamp size (http://www.diychatroom.com/f7/riser-clamp-size-194549/)
dgfit 01-22-2014 08:38 PM
Riser clamp size
I need a riser clamp to hold a section of my cast iron stack while I cut it. The outer dimension of the stack is 5" so I asked for a 5" riser clamp. But it seems to big. I expected it to wrap pretty close around the pipe but it doesn't. Did I ask for the wrong size?
joecaption 01-22-2014 08:47 PM
Sure it's not a 4" pipe?
http://www.engineeringtoolbox.com/ca...ns-d_1751.html
dgfit 01-22-2014 09:17 PM
I'll check the measurements. Thanks.
joecaption 01-22-2014 09:39 PM
If this is a residential house you have 4" cast not 5".
plummen 01-22-2014 11:29 PM
Ive never even seen 5" pipe .
3-4-6-8-10.........
TheEplumber 01-22-2014 11:36 PM
199 Attachment(s)
3-4-6-8-10.........
Its rare but it does exist, seen it twice in 25 years.
OP- get a clamp for 4" CI. Lengthen the bolts if needed
tonysteve66 01-23-2014 05:24 AM
Agree with TheEplumber..
We not have much uses of drain iron stack. but if size is your're sayin..5"
the best option in a 4" riser clamp ..
A normal riser clamp have 2" screw.. so it is good with that
dgfit 01-23-2014 08:33 AM
Yeah I remeasured and I don't know how I convinced myself it was 5 inches. Going back to get a 4 inch clamp.
Bondo 01-23-2014 12:00 PM
Ayuh,.... There's yer Problem,.....
Pipe is sized by it's Inside Id,...
dgfit 01-23-2014 07:28 PM
The 4" clamps fit great :)
