Ripping Pvc Pipe Lengthwise - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-12-2012, 07:08 AM   #1
Stay-at-home GC
Ripping pvc pipe lengthwise
I need to rip 16' of 8" ABS or PVC. Suggestions?
Snap a chalk line from end to end and free hand it?
Build an L shaped jig and use a circular saw with a rip guide?
Scrap the whole project and head for the bar?
Can correctly identify Shinola 3 out of 5 times*
*Under ideal conditions
Some days, my Life needs a Rewind/Erase Button.
CplDevilDog is offline   Reply With Quote
Old 03-12-2012, 07:33 AM   #2
The last should be first.........
The method depends on how accurate the cut must be. For not too.....just wing it. For a very accurate cut, you need something to hold the saw in proper alignment.
Old 03-12-2012, 08:00 AM   #3
the Musigician
DangerMouse's Avatar
I ripped a 4" tube on my table saw with a fine toothed blade. Worked fine.
DM
Old 03-12-2012, 10:14 AM   #4
Doing it myself
Alan's Avatar
Rewards Points: 2,086
DM
I was going to say something similar.
Journeyman Plumber
Old 03-12-2012, 11:06 AM   #5
Ravenworks's Avatar
DM
Do it all the time,be extremely careful and do it slowly. I try to avoid doing this practice if at all possible because I have that little guy in the back of my head telling me "No don't do it"
Ravenworks is offline   Reply With Quote
Old 03-12-2012, 11:44 AM   #6
Stay-at-home GC
Thanks, I'll go the circular/wing it route and see how our goes.
Building two "trays"to store my millwork in (and fishing poles)
Best way to join Poly pipe, for a water pipe repair. carl1864 Plumbing 10 11-03-2014 01:31 PM
Working with B-Vent pipe for WH vent BobN HVAC 16 01-26-2012 12:58 AM
Qs about the 1/2"dia brass pipe we bought smoochas Plumbing 10 02-21-2011 10:23 AM
What’s the best way to remove pipe from T Jaylyn Plumbing 2 02-03-2011 02:05 AM
